  1. Jul 11, 2024 at 11:06 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    There are two other members that do that often in the 1st Gen section
    I thought it was just a critter thing, but it seems to be popular with boomers in general
    Wonder why :rofl:
  2. Jul 11, 2024 at 11:14 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    no I just had to move them out of the way of the timing cover. I suppose I could’ve pulled one loose by mistake. I’ll take a closer look when I get home
  3. Jul 11, 2024 at 11:19 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    One of my favourite opening scenes to a movie ever
    https://youtu.be/lcLJj6i1LTs?si=-ueGLxHJW3dVrSwE
    eon_blue[QUOTED] likes this.
  4. Jul 11, 2024 at 11:34 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Maybe disconnect and reconnect that cam position sensor connector we had you look at too
  5. Jul 11, 2024 at 11:47 AM
    time623
    James
    AZ
    Is this supposed to be connected to something? Can't remember if I have a loose connector there too..
    Kwikvette likes this.
  6. Jul 11, 2024 at 11:53 AM
    Wulf
    rock raisin
    my team is pretty good about keeping meetings between 9-5pm but today I had to meet with a customer so it was a very early morning lol
    Kwikvette[QUOTED] likes this.
  7. Jul 11, 2024 at 12:33 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I was gunna see if you can just the controller maybe or get a set of their wire schematics
  8. Jul 11, 2024 at 12:43 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Meh, ordered one should have all I need besides an air drier and a box, plug it into one of our solar packages at work to see if it works.
    Sperrunner[QUOTED] likes this.
  9. Jul 11, 2024 at 12:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If these will be left out for awhile, just get a simple self-draining water separator and attach a vinyl tube to the end of it leading towards the ground outside
  10. Jul 11, 2024 at 12:52 PM
    JKO1998
    Utah
    I'm worried about freezing
  11. Jul 11, 2024 at 12:52 PM
    eon_blue
    Azusa, CA
    Ozark_RegCab[QUOTED] likes this.
  12. Jul 11, 2024 at 12:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ok then don't run any filtering at all
  13. Jul 11, 2024 at 12:55 PM
    Wulf
    rock raisin
    if there's enough water that your filter/dryer is freezing solid you're probably already fucked lol
  14. Jul 11, 2024 at 12:55 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Put on a coat?
  15. Jul 11, 2024 at 12:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Exactly
    Any filtering in general, will capture moisture which can cause a freezing issue
    I was more or less specifying what type of drier he should use, especially if these systems will be out and about everywhere
    Using a paper filter type, or even a desiccant setup, will require the end user to replace/replenish said media
    An auto draining water separator is basically set it and forget it
  16. Jul 11, 2024 at 12:58 PM
    JKO1998
    Utah
    Water collecting in the tank
    Gotta have something, they get water in them for sure
  17. Jul 11, 2024 at 12:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No shit :rofl:
  18. Jul 11, 2024 at 12:59 PM
    JKO1998
    Utah
    Frozen tank is no good
  19. Jul 11, 2024 at 1:00 PM
    Speedytech7
    Package it so the drier is near to the pumps which generate considerable heat in use
    Wulf likes this.
  20. Jul 11, 2024 at 1:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Absolutely not, read my reply above!
    Cause if I recall correctly, this will be a prototype to something you wish to build but you'll require a shit ton of them
    I don't think you want to go on an expedition replacing the media in each and every single one of them
