  1. Aug 2, 2024 at 12:14 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I'm hoping work will pay me for what I have into this, maybe try to build another.
    Kwikvette[QUOTED] likes this.
  2. Aug 2, 2024 at 12:15 PM
    JKO1998
    Utah
    Oh it'll be fine regulatory wise, I don't think they're are any requirements there
  3. Aug 2, 2024 at 12:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Just make sure you test for ground between points after wiring stuff up and see if there's any resistance. You never know if the box isn't fully welded or something or if perhaps the holes are painted
    jubei likes this.
  4. Aug 2, 2024 at 12:41 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Lot of experience working with small stuff eh :luvya:
  5. Aug 2, 2024 at 12:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    And I thank you for it for coming over to my house for a few days :luvya:
    time623[QUOTED] likes this.
  6. Aug 2, 2024 at 1:03 PM
    time623
    James
    AZ
    That was supposed to stay between us
  7. Aug 2, 2024 at 1:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What happens outside the lunchtable, gets mentioned in the lunchtable to allow for humiliation and ridicule :luvya:
  8. Aug 2, 2024 at 1:15 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Small dick joke!
  9. Aug 2, 2024 at 1:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    They can't all be gifted like us
    Tour991[QUOTED] likes this.
  10. Aug 2, 2024 at 1:23 PM
    Tour991
    James
    South Reno/Tahoe
    Olivia's trying to get Koko to play. Kokos not having it.
    CS_AR, Speedytech7[OP] and Kwikvette like this.
  11. Aug 2, 2024 at 1:35 PM
    JKO1998
    Utah
    Well it works, but it also leaks everywhere so that's good
  12. Aug 2, 2024 at 1:36 PM
    Speedytech7
    Not yet experienced in the ways of Teflon huh? It's okay you'll learn in good time
  13. Aug 2, 2024 at 1:40 PM
    JKO1998
    Utah
    It says not to use tape, but I did, gotta find whatever else
  14. Aug 2, 2024 at 1:40 PM
    Speedytech7
    Pipe dope works but really tape+dope works best. I just use tape usually but you gotta wrap enough of it
  15. Aug 2, 2024 at 1:42 PM
    JKO1998
    Utah
    And here I thought I taped too much
  16. Aug 2, 2024 at 1:44 PM
    JKO1998
    Utah
    Also the hose clamps are leaking, wondering if I needa tighten them more or if they're work at all
  17. Aug 2, 2024 at 1:45 PM
    Speedytech7
    I try to avoid using worm clamps as much as possible. Especially if you're going to make more of these things get some cheap oetiker clamps. Then all you have to do is slip one on and use the little crimp pliers and it provides good tension around the whole joint and it's much cheaper than buying worm clamps too
    CS_AR likes this.
  18. Aug 2, 2024 at 1:47 PM
    JKO1998
    Utah
    Noted
  19. Aug 2, 2024 at 2:54 PM
    time623
    James
    AZ
    Is $180 fair cost on a tire swap + balance + disposal for 4 tires, from one set of wheels to my set of wheels?
  20. Aug 2, 2024 at 2:57 PM
    Speedytech7
    Pretty good really, my local place charges that much for small tires (32 and below) and an extra $5 for 33 and over.
