  1. Sep 9, 2024 at 5:08 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  2. Sep 9, 2024 at 5:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Machine torch for the Hypertherm
    Grab the other plasma cutter; selling my machine torch for more than I thought I would so I'd be able to let my plasma cutter go for less
    So far I've got 2 plasma cutters, 2 machine torches, and 2 hand torches :rofl:
  3. Sep 9, 2024 at 5:21 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I would but i dont really need one. Plus im buying a airsoft gun again me and some buddies gunna get into it again
    Kwikvette[QUOTED] likes this.
  4. Sep 9, 2024 at 5:52 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
  5. Sep 9, 2024 at 6:06 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    I love to print things out like this and post them in my office for all my instructors to see.
  6. Sep 9, 2024 at 6:11 PM
    Running Board Man
    Running Board Man Well-Known Member
    Tell me about it
  7. Sep 9, 2024 at 6:13 PM
    Running Board Man
    Have you ever run pulsed mig?
    It's all the shop I work at now does
    But I don't quite know how to set "arc length" as I'm used to volts being the temperature control when it comes to wire fed stuff
  8. Sep 9, 2024 at 6:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I had it on the 350P I ran at my last shop
    You simply adjust the frequency at which you want it to run as it helps with heat when you're running beads
    I used it maybe a handful of times running stuff uphill on large frames because the crossmembers were thinner gauge
    What machine you running?
  9. Sep 9, 2024 at 6:45 PM
    Running Board Man
    Oh God... There's like 5 different combos of miller power sources and wire feeders that I'm stuck with using none of which I know and some of which look like a forklift dropped something on in 2004
    Some of the wire feeders feed wire like they're mounted on a helicopter flying over a rice patty in vietnam in 1967
    We're only allowed to run downhill so we have problems with pinholes when grinder dust is present
    No matter what I set any machine at it feels wayy too hot... Need to travel very fast to make a decent looking bead but questionable penetration
  10. Sep 9, 2024 at 6:54 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Sperrunner and Running Board Man like this.
  11. Sep 9, 2024 at 7:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oooh you're running some transformer-based machines aren't ya?
    Those Miller's have always run extra hot for me, regardless of the shop I was at. Just seems they all run that way.
    I get you though. We were allowed to run beads our way but at this job, you had to pass a few weld tests to even be hired and that determined the work you'd do at said shop.
    I only ever ran pulse uphill, and ran it super hot when I did stainless. Never ran pulse for mild.
  12. Sep 9, 2024 at 7:43 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    When you gunna start welding copper
  13. Sep 9, 2024 at 7:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Why would I if I can just use that as excuse for you to come over :burp:
    Sperrunner[QUOTED] likes this.
  14. Sep 9, 2024 at 7:50 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You need your pipes fixed? Lmao
  15. Sep 9, 2024 at 7:51 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Not the LT meet we wanna see
    unstpible likes this.
  16. Sep 9, 2024 at 7:52 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You must be looking for the LT Meat
    Wulf and Sperrunner like this.
  17. Sep 9, 2024 at 7:59 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    What are you doing step welder
    Wulf and Kwikvette[QUOTED] like this.
  18. Sep 9, 2024 at 9:08 PM
    Tour991
    James
    South Reno/Tahoe
  19. Sep 9, 2024 at 9:29 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  20. Sep 9, 2024 at 9:37 PM
    crawlerjamie1
    crawlerjamie1 Granite guru
    Dudes I’m having a helluva time trying to figure out why my 2rz buggy is running so shitty.
    Symptoms: hesitates when on the throttle. Feels like it’s struggling on when on the throttle. Backfiring into the intake. Rough idle.
    New Toyota oem maf, new 02 sensors, new iac, new oem Toyota spark plugs. No carbon tracking on any spark plugs. Checked for vacuum leaks with with QuickStart and propane. Nothing noted. Engine is a 1998 2rz (two coil) from a 2wd Tacoma.
