  1. Sep 14, 2024 at 11:49 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I think it has no compression or something like that
  2. Sep 14, 2024 at 12:29 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    He should take it to another mechanic.
    jubei and Sperrunner[QUOTED] like this.
  3. Sep 14, 2024 at 1:15 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Uh thanks eBay, I'll consider it. The price is pretty reasonable
    eon_blue, Sperrunner and 0xDEADBEEF like this.
  4. Sep 14, 2024 at 1:50 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Nice to now I can double my battery storage I guess. Need my charge controller and figure out how I want to run the wires and pipe. IMG_2955.jpg
    unstpible and Sperrunner like this.
  5. Sep 14, 2024 at 1:50 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Your search history must be crazy
  6. Sep 14, 2024 at 1:54 PM
    Tour991
    James
    South Reno/Tahoe
  7. Sep 14, 2024 at 2:47 PM
    JKO1998
    Utah
    Pretty? Does it work? I think
    unstpible likes this.
  8. Sep 14, 2024 at 3:57 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I'm usually not a fan of Hananero peppers but this is some good salsa
    A buddy who stayed at my house for a while after getting divorced left it behind, he claimed it was the closest he could get to his mom's salsa over the counter
    0xDEADBEEF and Kwikvette like this.
  9. Sep 14, 2024 at 3:58 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    So, I bought a new axle from Rock Auto. This axle has the same part number as a Track Motive by Wonn Industries.
    I'm taking it apart to see how good or bad it is. I need to separate the axle shaft from the Birfield joint. I found a video about this. It's not hard. I just need a big vice.
    https://youtu.be/OzSNn1UHbmc?si=fQbv4WliEFSI9FHA
    Tour991 likes this.
  10. Sep 14, 2024 at 4:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Only had about an hour to do any real work today so I drew cut this up as a means of holding my clamps
    M14 hardware arrives tomorrow which I'll use to attach to one face of my fixture, after which I'll weld it together and mount it
    Used some spare hardware to attach the other mount holder I made
    M12 to temporarily hold it up, I'll be using M14 hardware for this as well
  11. Sep 14, 2024 at 4:24 PM
    CS_AR
  12. Sep 14, 2024 at 4:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's a good one, I'll keep that one in mind
    Tour991 and CS_AR[QUOTED] like this.
  13. Sep 14, 2024 at 5:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  14. Sep 14, 2024 at 6:21 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I lock tight all the Lugnuts before I sell a car.
  15. Sep 14, 2024 at 6:27 PM
    Tour991
    James
    South Reno/Tahoe
    Did my 1st ruff assembly on the locker today.
    Feel like I learned a lot from this. Still needs a lot of tuning.
    Most important thing I figured out is heat and cold make things so much easier. Bearings and races slide in like butter.
  16. Sep 14, 2024 at 6:29 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
  17. Sep 14, 2024 at 6:34 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah bearing heaters are super nice. But a toaster oven works just as good lol
  18. Sep 14, 2024 at 7:00 PM
    Tour991
    James
    South Reno/Tahoe
    I found freezing the pinion gear was the key. Hardly any heat just a lot of cold.
    Sperrunner[QUOTED] likes this.
  19. Sep 14, 2024 at 7:24 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I teach doing bearings on the electric motors. And we use a bearing heater to be able to get the bearings onto the shaft. Man because no one has the time to freeze the shaft at work or carries around liquid nitrogen to be able to freeze it right away
    Tour991[QUOTED] likes this.
  20. Sep 14, 2024 at 7:56 PM
    Tour991
    James
    South Reno/Tahoe
    i just froze them over night because I had plenty of time. Separating the pinion gear and the main pinion is going to be another adventure.
