  1. Sep 18, 2024 at 10:43 AM
    eon_blue
    Azusa, CA
  2. Sep 18, 2024 at 10:50 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The guy that runs the Celina52 diner page runs this one too
    Wulf and eon_blue[QUOTED] like this.
  3. Sep 18, 2024 at 10:51 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Is that before or after skydiving?
    eon_blue[QUOTED] likes this.
  4. Sep 18, 2024 at 10:51 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Yeah saw the explain on the other thread.
    it does seem super weird... the only thing I didn't see mentioned, and usually because its fucking obvious, is the tension/load on whatever cable track/hanging system you have, but still not like that would explain the issue you are experiencing.
    the only thing that seems like it would cause the issue you are experiencing to me, is that the new torch is messed up...
    Kwikvette[QUOTED] likes this.
  5. Sep 18, 2024 at 10:53 AM
    eon_blue
    Azusa, CA
    Yeah, just a few minutes after you posted that original image on the last page I had the same post pop up in my feed, followed by that other one
  6. Sep 18, 2024 at 10:56 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tension would change based on where the torch is above the table; the defect appears anywhere a test piece is cut meaning an area where in theory, tension would be greater, as well as an area where tension would be the least. By that theory as well, tension would be more when cutting the lower edge (as it is farther away from the cable mount) than the top edge. Yet bottom edge is fully square.
    I don't mind cutting the zip ties to release any of it but the issue was not present on the UPM-105 which, actually has a stiffer cable. The Hypertherm cable is thicker, but flexes even better.
    I did question the machine torch being an issue, but Hypertherm tech specialist responded back with my own provided statement "since you rotated the torch 45 and 90 degrees, the beveling should've moved with the torch if it was a torch issue"
  7. Sep 18, 2024 at 11:01 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Bandido Thanks for reading the other thread though and checking the pics out; gives you a good understanding of all I've done.
    I need to do a 3" x 3" test cut and record it for Hypertherm.
    Will be providing pictures with said video.
    Before doing that though, I'll need to do a pressure check using Hypertherm's built-in function to confirm the solenoid is working correctly.
    Bandido likes this.
  8. Sep 18, 2024 at 11:04 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    ah, yeah I didn't realize you had reoriented the torch, but got the same results.
    are you running a drag chain/track or the stock hanger? -when I first set up my drag chains I had a L/R bevel when the head moved in a way that straightened the track, but that was before I was running a machine torch, and wouldn't think this issue would exist without it being really obvious.
  9. Sep 18, 2024 at 11:06 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Stock hanger.
    The left to right bevel only occurs on the top edge, leaving the bottom edge alone.
    That's what's odd, if the axis is the issue, beveling should occur on both the top and bottom edge.
  10. Sep 18, 2024 at 11:10 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Which, on top of some more troubleshooting, I'm doing plugs and wires and pcv on my friend's Tacoma today
    Cleaning up the IAC and throttle body recently lead to the truck running fine and passing smog yesterday
    CS_AR likes this.
  11. Sep 18, 2024 at 11:11 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    yeah top edge only is super weird, and part of what makes me think its inertial/ caused by getting to that position... given all the other things you have checked, unless you have not run a CCW path?
    I'm sure you'll get it figured out.
  12. Sep 18, 2024 at 11:14 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Literally before you posted this, I thought to myself if I should forcibly run a CCW path.
    But this could lead me to getting an artificial square edge though - but then that would be cutting items incorrectly and a part that is supposed to remain whole would get a lead in/out pierce mark.
    Bandido[QUOTED] likes this.
  13. Sep 18, 2024 at 11:15 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    but if it does get you to an "artificial" square edge it also lets you know something not so obvious in the carriage does actually needs adjustment
  14. Sep 18, 2024 at 11:17 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    By that theory, the bevel should move to the bottom edge though and we're still fighting bevel.
    I may give it a try as a final result, but will bring it up to Hypertherm after I do my test cuts and send them a video and pictures.
  15. Sep 18, 2024 at 11:25 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    yeah good next steps.
    if its not the carriage/head, it could still be a torch tolerancing issue if something is looser in the torch than is should be... that electrode position can influence the arc cone shape, just like a tungsten grind (I would be really surprised if this was the case given the consistent direction)
    good luck!
  16. Sep 18, 2024 at 11:31 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Air pressure test complete; holding it for 5 seconds flashes 66
    Letting air flow through the torch goes back 65 and 66 but more steadily shows 66 as the working pressure which puts me at 0.5 to 1psi
    Well within the 1-2psi Hypertherm suggested
    Bandido likes this.
  17. Sep 18, 2024 at 1:37 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Exactly, what am I supposed to do at work all day if I don't have a bunch of bs in here to stay caught up on?
    Speedytech7[OP] and Wulf like this.
  18. Sep 18, 2024 at 1:43 PM
    Wulf
    rock raisin
    read tech for your upcoming mods/repairs
    time623[QUOTED] likes this.
  19. Sep 18, 2024 at 5:20 PM
    time623
    James
    AZ
    unstpible likes this.
  20. Sep 18, 2024 at 5:53 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Apparently there's a difference in NPT and NPTM threads
    hmmmm
