  1. Sep 18, 2024 at 8:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :fistbump:
  2. Sep 18, 2024 at 9:02 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I watched the whole video. Clever, and I respect the thought that went into the design, but can't say I'm that excited about the functionality. It would be more interesting if it allowed FWD operation, but some quick googling suggests that's not really doable with these transfer cases.
    I wonder if a J-shifter could be modified to allow 2-low? I remember a friend of mine saying he was going to do that with his Bronco II. Sounded like it was just a matter of modifying or rearranging the stops in the case so you could push the lever forward from 2-high.
  3. Sep 18, 2024 at 9:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah they can but you have to take the case apart to take a ball that stops that from happening out
    jubei, Wulf and 04Pre_Runner like this.
  4. Sep 18, 2024 at 9:14 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I dun fucked up and ordered the wrong part :anonymous:
    Damn special order too so it's non refundable but I guess I know why the steering rack was so cheap
    Also can I just say FUCK one more time
  5. Sep 18, 2024 at 9:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well, now you can rebuild yours
    unstpible[QUOTED] likes this.
  6. Sep 18, 2024 at 9:18 PM
    Speedytech7
    Well if you ever decide to rebuild a steering rack now you've got the rack part
  7. Sep 18, 2024 at 9:20 PM
    unstpible
    Derek
    Cedar City, Utah
    When my front dif actuator wasn't working I had 2Lo so it's definitely doable just need a secondary switch to control the front dif actuator
  8. Sep 18, 2024 at 9:23 PM
    unstpible
    Derek
    Cedar City, Utah
    I guess I could rebuild instead of replacing but that's not what I had in mind.
  9. Sep 18, 2024 at 9:25 PM
    Speedytech7
    It's a lot of work too
  10. Sep 18, 2024 at 9:30 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    I’ve looked into that before, people have done it and it looks pretty easy. Just one switch wired into the add signal wire. I think I saw somewhere that it’s actually technically 3Lo due to front drive shaft still spinning. Only twin sticks for true 2lo
  11. Sep 18, 2024 at 9:40 PM
    unstpible
    Derek
    Cedar City, Utah
    Probably not cheap either since I'd still need inner tie rod ends and a handful of other pieces. I feel like I'm just going to eat the money and order the correct rack
    44250-35042
  12. Sep 18, 2024 at 9:44 PM
    unstpible
    Derek
    Cedar City, Utah
    Practically 3Lo now without a front locker
    time623[QUOTED] likes this.
  13. Sep 18, 2024 at 9:46 PM
    time623
    James
    AZ
    I’m 2wd by that metric :pout:
  14. Sep 18, 2024 at 9:56 PM
    unstpible
    Derek
    Cedar City, Utah
    For now!
  15. Sep 19, 2024 at 3:40 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Where in Pennsylvania? 2 winters there won't destroy it, if your concerned just fluid film it.
    The cost of living there vs Cali is gonna be a real eye opener for ya. You actually can make it happen working at Sheetz @Speedytech7
  16. Sep 19, 2024 at 3:51 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Headed to the coal mines?
    you get to learn about winters too
    Speedytech7[OP] likes this.
  17. Sep 19, 2024 at 4:36 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Well congrats man! As someone who just picked up and moved 1000 miles I can imagine the thoughts you're going through. Hopefully it all goes smooth! It's been a fun time learning to live somewhere completely new. Are you moving out here solo?
    As far as the truck, these trucks don't take much to rust, but with the right prep you can help it survive. As mentioned, learn how to fluid film your truck or something similar and let her rip.
    Where in Pennsylvania are you moving to exactly?
  18. Sep 19, 2024 at 4:51 AM
    6P4
    Colorado Springs
    I have manual hubs, so don't need the switch... but might have to get my shoes dirty.
  19. Sep 19, 2024 at 5:23 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I learned that Nissan Oil Pressure sensor switches use BSP - British Standard Pipe Thread instead of NPT. I used an adaptor to connect to a pressure gauge.
  20. Sep 19, 2024 at 5:23 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Yeah they will. I’ve never gotten fittings on Amazon before. Ace, lowes and Home depot generally have a ok selection of small stuff. Gots most things done
