  1. Sep 24, 2024 at 3:51 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    unstpible[QUOTED] likes this.
  2. Sep 24, 2024 at 3:57 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
  3. Sep 24, 2024 at 3:59 PM
    unstpible
    Derek
    Cedar City, Utah
    The last suction cup one I had got irritating because it would pop off the window at the most inconvenient time.
    Wulf likes this.
  4. Sep 24, 2024 at 4:03 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Yeah you have to support the weight of the phone somewhere other than the suction cup. This is how I had it in my old car, never came off once. The weight of the phone is effectively pushing the cup into the windshield instead of twisting it off the windshield like they normally do.
  5. Sep 24, 2024 at 4:08 PM
    6P4
    Colorado Springs
    I use a magnetic mount (it doesn't hold up to off-road use, but is fine for on-road) affixed to the clock blank. It is partially obstructed by the steering wheel but it's not horrible.
    TEQ mount does look interesting. If you just want to mount the phone I bet you could make a decent mount out of flat strap or 90-degree angle stock too.
    time623 likes this.
  6. Sep 24, 2024 at 4:09 PM
    unstpible
    Derek
    Cedar City, Utah
    I did have the arm resting on the dash to help keep the leverage down but it didn't have an actual bracket like that
    time623[QUOTED] likes this.
  7. Sep 24, 2024 at 4:11 PM
    unstpible
    Derek
    Cedar City, Utah
    I need something for off road use. On pavement I can just put the phone under the radio in the cubby and it's pretty visible but it doesn't stick around when the pavement ends
  8. Sep 24, 2024 at 4:11 PM
    time623
    James
    AZ
    Damn, yeah I guess I've been lucky then
    None of them have ever held up offroading if you keep your phone in it though. Broke the one I have in the truck right now when I was in moab recently lol
    Every single one I've had has broke at the plastic ball joint between the mount arm and the phone holder
  9. Sep 24, 2024 at 4:12 PM
    6P4
    Colorado Springs
    The issue with my setup is the magnetic mount. I think the RAM mount in the same spot could be good.
  10. Sep 24, 2024 at 4:13 PM
    time623
    James
    AZ
    There might be something out there (RAAM Maybe) that you can mount to the oh shit handle. I'd put a phone there if I didn't have this ultragauge mount there.
    https://www.srqfabrications.com/pro...IHph3FZ39VuW0mDUIoCsMPnd8yjZ5oXwTJgNE7FQpxA5I
  11. Sep 24, 2024 at 4:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    +1 for a Ram mount
    Used it in the 4R, Taco, and the Land Cruiser
    unstpible likes this.
  12. Sep 24, 2024 at 4:14 PM
    unstpible
    Derek
    Cedar City, Utah
    I wonder if the ram mounts can be rotated so one of the arms is underneath the phone instead of both arms on the sides.
    They have a couple bolt down options that would at least stay mounted
  13. Sep 24, 2024 at 4:14 PM
    6P4
    Colorado Springs
    Wulf, unstpible and time623[QUOTED] like this.
  14. Sep 24, 2024 at 4:23 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Its probably that diesel brother dude that has one out there
  15. Sep 24, 2024 at 4:29 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Besides the fact it is registered to the army :rolleyes:
  16. Sep 24, 2024 at 4:30 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I just saw the blackhawk thing didn’t see anything about The army
    unstpible and m3bassman[QUOTED] like this.
  17. Sep 24, 2024 at 4:49 PM
    unstpible
    Derek
    Cedar City, Utah
    It's right there in the black section below the map and the info section
    Sperrunner[QUOTED] likes this.
  18. Sep 24, 2024 at 4:54 PM
    unstpible
    Derek
    Cedar City, Utah
    Do the arms rotate or is the grip good enough that it's not an issue
  19. Sep 24, 2024 at 5:00 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I can't believe how cool my engine stays with this new fan clutch. I even got as low as 163f while going downhill, and it barley even hits 180f on the highway. It's not like I had overheating issues before, but I definitely won't now. Thanks to @Kwikvette for the suggestion. If I ever get another Land Cruiser this will be the first thing I do.
    Kwikvette likes this.
  20. Sep 24, 2024 at 5:04 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Don’t.
    :rofl:
    Wulf, Tour991, eon_blue and 1 other person like this.
