  1. Sep 25, 2024 at 3:13 PM
    eon_blue
    Azusa, CA
    I want to see a kid wear this on a t-shirt to church
  2. Sep 25, 2024 at 3:13 PM
    Wulf
    rock raisin
    they should have other priorities, like making parts that fit without needing modifications right out of the box
  3. Sep 25, 2024 at 3:15 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Don't worry, you probably aged out for that.
    time623[QUOTED] and Kwikvette like this.
  4. Sep 25, 2024 at 3:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ugh, I need to borrow a mag drill
    That or really just try some new bits, but a mag drill would be a quick and easy/cheater way
  5. Sep 25, 2024 at 3:25 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Regular drill and a floor jack not gud enough huh
  6. Sep 25, 2024 at 3:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    My sciatica just kicked in the moment I read that :rofl:
    Really I just need more force (from above), and I'm being lazy in that I don't want to remove the water bed on my plasma table.
    The stainless steel is pretty tempered from the many times I've placed direct heat on it in the areas I want to drill through :bananadead:
  7. Sep 25, 2024 at 3:30 PM
    Speedytech7
    Carbide bit
  8. Sep 25, 2024 at 4:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You reminded me that I had one, so I used it as my pilot hole and got them done
    Bought it sometime last year when I had to drill through a sword and other hardened shit
    Calling it a day, been out all day, had several drinks and some shots so I'll head out tomorrow to buy some bonded washers and PVC pipe
    Wulf likes this.
  9. Sep 25, 2024 at 4:32 PM
    Wulf
    rock raisin
    can't find any vacuum leaks in the Tacoma, also can't figure out why it idles at 1100 rpm lol
    wondering if one of the intake gaskets in the valley has a leak. felpro was all I could get when I changed my injectors in 2020
  10. Sep 25, 2024 at 4:33 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Needs a new engine if it doesn't run right
  11. Sep 25, 2024 at 4:34 PM
    Wulf
    rock raisin
    maybe I should drop a rag into the timing belt since it's already junk
  12. Sep 25, 2024 at 4:34 PM
    JKO1998
    Utah
    Washers are better
    Bandido and unstpible like this.
  13. Sep 25, 2024 at 4:36 PM
    Wulf
    rock raisin
    drinks sound kind of good lol
    Kwikvette[QUOTED] likes this.
  14. Sep 25, 2024 at 4:44 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Is ur thermostat good
  15. Sep 25, 2024 at 4:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Had the funeral today; not a day to be sad but really celebrate him
    It was his birthday today, and he had made his peace some time back so they had his playlist playing his music, his eulogy he wrote (and spoken out loud by his sister) and more
    And to celebrate, he insisted on having an open bar and people having shots for him
  16. Sep 25, 2024 at 4:49 PM
    Wulf
    rock raisin
    that sounds like the way to do it up right, a proper celebration of his life
  17. Sep 25, 2024 at 4:52 PM
    Wulf
    rock raisin
    that is the warm idle rpm lol it's even higher when cold lmao
    scanner shows 190-192 at idle while warm
    LT FT -8
    TPS 8.6 pct
    timing advance 9 deg
  18. Sep 25, 2024 at 4:56 PM
    time623
    James
    AZ
    Shouldn't the LT FT be ~0 at idle?
  19. Sep 25, 2024 at 4:59 PM
    Wulf
    rock raisin
    possibly? i thought +-10 pct was acceptable
  20. Sep 25, 2024 at 5:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just drop a bigger cam in it
