  1. Oct 9, 2024 at 4:36 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Do: Fix it
    Dont: Break it
    unstpible and Wulf like this.
  2. Oct 9, 2024 at 4:45 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Another quick and probably silly question…
    is mass air flow sensor cleaner ok to use to search for vacuum leaks? I’ve seen brake cleaner and TB cleaner is ok but nothing about MAF cleaner..
    I think it is?
  3. Oct 9, 2024 at 5:08 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Why would no where local have a reverse switch, prolly just run what I have ig
  4. Oct 9, 2024 at 5:50 PM
    JKO1998
    Utah
    Why do people think Westcott built trucks are cool?
  5. Oct 9, 2024 at 5:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    "Built"?
    Looks like just a spacer kit with Yota Pro shocks
  6. Oct 9, 2024 at 5:53 PM
    JKO1998
    Utah
    Right
  7. Oct 9, 2024 at 5:53 PM
    JKO1998
    Utah
  8. Oct 9, 2024 at 6:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Podiatrist appointment confirmed finally
  9. Oct 9, 2024 at 6:15 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Will you do my original Xbox. The DVD drive is dead and I can't find a replacement anymore.... But I can supply a large hard drive for it
  10. Oct 9, 2024 at 6:17 PM
    Speedytech7
    I don't know if it's flammable. If it says keep away from open flame it's probably good to test with.
    Logans2001[QUOTED] likes this.
  11. Oct 9, 2024 at 6:29 PM
    JKO1998
    Utah
  12. Oct 9, 2024 at 6:35 PM
    JKO1998
    Utah
  13. Oct 9, 2024 at 6:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  14. Oct 9, 2024 at 7:14 PM
    Wulf
    rock raisin
    possibly, could be a fun winter distraction lol
    there is a way to hot swap the disk drive to PC, clone the necessary keys, and build the new one into a bootable/soft modded drive. I've never gone that route though.
    is the laser bad or the whole drive? replacement lasers are available for some of them for $15~
  15. Oct 9, 2024 at 7:16 PM
    Speedytech7
    To be honest I don't know. The drive opens and closes and I think it spins up so my guess would be the laser
  16. Oct 9, 2024 at 7:20 PM
    Wulf
    rock raisin
    there are also some PC drives that can be flashed to work
    https://consolemods.org/wiki/Xbox:DVDROM_Flashing
    if you have a working dvd drive then iirc you can slap in the big hard drive and use a bootable disk to flash it with the modded xbox dashboard.
    other path is soft mod dashboard using game exploit with hacked splinter cell / mech assault save, then use a PC util to prepare the new HDD with keys extracted from the mod dashboard
    jubei and Kwikvette like this.
  17. Oct 9, 2024 at 7:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    See, this is the kind of info I was referring to regarding the Saturn
    I'll have to do some digging; apparently I have a Gen 2 and there are different mobo's used o_O
    Wulf[QUOTED] likes this.
  18. Oct 9, 2024 at 7:36 PM
    Wulf
    rock raisin
    Kwikvette[QUOTED] likes this.
  19. Oct 9, 2024 at 8:00 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
  20. Oct 9, 2024 at 8:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    m3bassman[QUOTED] likes this.
