  1. Dec 1, 2024 at 1:00 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I saw the saddest of sads today at the junkyard: A 3RZ, auto, RWD 4Runner. Somehow it still managed to find enough speed to make some very interesting damage.
    The engine didn't turn anymore but its MAF and injectors will live on in my parts stash.
    C_tanner, Speedytech7[OP] and Wulf like this.
  2. Dec 1, 2024 at 1:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah, putting out nearly 500ft lbs at the crank tho
    Wulf likes this.
  3. Dec 1, 2024 at 1:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's sick dude
    I'm gonna want a ride in it when I head up north :anonymous:
    Wulf and Speedytech7[QUOTED][OP] like this.
  4. Dec 1, 2024 at 1:56 PM
    Speedytech7
    It was an auto 2WD, this was truly it's kindest ending.
    Running Board Man and Sperrunner like this.
  5. Dec 1, 2024 at 2:11 PM
    6P4
    Colorado Springs
    Oddly, it had cruise control. I can only imagine it slowly bogging then violently downshifting as it tried to hold 55mph up a gentle grade.
  6. Dec 1, 2024 at 2:37 PM
    Running Board Man
    Running Board Man Well-Known Member
    Nothing says thanksgiving weekend like bumper to bumper interstate traffic
    0xDEADBEEF and Speedytech7[OP] like this.
  7. Dec 1, 2024 at 3:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ok this is some bullshit.
    GX won't crank, just a single click.
    Pull codes again and after replacing the camshaft sensor, I now pull both a camshaft position sensor (bank 1) code P0340 and crankshaft position sensor code P0335.
    Going to go and inspect all wiring but I made sure everything was away from the belts by using the factory loops and clips as well as ensuring the new sensor is fully plugged in.
  8. Dec 1, 2024 at 3:33 PM
    Speedytech7
    Single click is usually bad battery connetion
    Running Board Man, Wulf and Kwikvette like this.
  9. Dec 1, 2024 at 3:36 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I pushed in every plug with all my weight behind it in case something was loose
    Fired up finally :D
    I wonder if I hit the crankshaft sensor wire when I was pulling the accessory belt over the AC compressor
    Tour991, CS_AR and Wulf like this.
  10. Dec 1, 2024 at 4:11 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Air compressor just about to a month with no issues, changed the dryer beads once
    Kwikvette likes this.
  11. Dec 1, 2024 at 4:28 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
  12. Dec 1, 2024 at 4:30 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Sad to see the lives lost in that Cybertruck crash. FD's normal extinguishers would not put the fire out.
  13. Dec 1, 2024 at 4:36 PM
    Speedytech7
  14. Dec 1, 2024 at 4:37 PM
    m3bassman
    Green truck
    Hey now, did not give me an incomplete build to thrash.
  15. Dec 1, 2024 at 4:41 PM
    Speedytech7
    Well good news is I have adjusted the seat so it moves much easier now. You can try it again with 100% of the pedal. Oh and it has way more boost control tuning and another 6psi... I think that video was from Monte's wedding but truthfully I actually don't remember, but at least during that trip I was having boost control issues due to the altitude because I had never been up there and gotten a chance to set a base for it. Now I've got a base that works for all conditions. But at least since you last felt it in Boise it has another 6 lb on top
  16. Dec 1, 2024 at 4:43 PM
    m3bassman
    Green truck
    All I hear are excuses.... Pshhh
  17. Dec 1, 2024 at 4:44 PM
    Speedytech7
    That was a pretty accurate reproduction of the sound my blow off makes when I pass you
  18. Dec 1, 2024 at 4:55 PM
    m3bassman
    Green truck
    Hypothetically, since we've never had the trucks lined up.
  19. Dec 1, 2024 at 4:57 PM
    Speedytech7
    Well now it would kind of be like beating up a midget. I'd rather live in a world where you still believe you could win because it's a cold reality we live in and I want you to have something to keep you warm.
  20. Dec 1, 2024 at 5:05 PM
    m3bassman
    Green truck
    Look me ego isn't so fragile. Facts are facts, we haven't lined up before. And the video of your truck pulls same as mine. Nothing else is up for debate until we can line them up.
