  1. Dec 15, 2024 at 11:20 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I went through that over the TPS plug cracking up on me.
  2. Dec 15, 2024 at 11:35 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's knock sensor number two. Is that the one underneath the manifold? P0330 is the code I pulled for knock sensor #2.
    I was careful with both plugs in the valley, guess not careful enough :annoyed:
    Edit: Yep, looking up a diagram both 1 and 2 are in the valley with #2 being on the passenger side, and #1 being on the driver side.
    Looks like I'll have to pull off the manifold again one of these days. I ain't doing that shit today.
    Wulf and CS_AR[QUOTED] like this.
  3. Dec 15, 2024 at 11:39 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lots of room for shit boxes :bananadance:
    eon_blue[QUOTED] likes this.
  4. Dec 15, 2024 at 11:48 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So, would you take pictures of how you're able to do this without pulling the manifold off :rofl:
    How do you get it plugged back in?
    unstpible and CS_AR[QUOTED] like this.
  5. Dec 15, 2024 at 12:20 PM
    CS_AR
    Just a few minutes ago, Andrew snaked his hand under the lower intake and to start the KS bolt and finger tighten it. Once the bolt was started, then I take a long 1/4 drive extension with a universal joint and a 12mm to tighten it down. I hook up the knock sensor to the harness before we slide it under the intake to bolt it down. I wanted to get this done before le leaves for CA tomorrow. There is no way that I can do this with my XL glove size hands.
  6. Dec 15, 2024 at 12:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Holy shit, his hand fits in there?
    If the manifold is off, easy peasy. But I'd expect an open ended wrench if you've got it plugged in first and then you try to tighten it?
    I'll try it tomorrow, car's hot right now and I'm tired :bananadead:
    Worst case I'm buying a knock sensor connector from Rock Auto and might go at pulling the entire manifold upper/lower sometime in the next few weeks. Don't want to do it again anytime soon.
    CS_AR[QUOTED] likes this.
  7. Dec 15, 2024 at 12:24 PM
    CS_AR
    Figuring that I would have a KS problem, I replaced both when I had it open.
  8. Dec 15, 2024 at 12:27 PM
    CS_AR
  9. Dec 15, 2024 at 12:29 PM
    CS_AR
    Nissan has a whole different KS design. I think Toyota may have adopted this microphone design in later years.
  10. Dec 15, 2024 at 12:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh ok, I was about to say "that's for a Nissan"
    This is all I pull up for the Toyota/Lexus
    About to order a knock sensor too just to be safe
  11. Dec 15, 2024 at 12:32 PM
    CS_AR
    That looks like Toyota.
  12. Dec 15, 2024 at 12:35 PM
    CS_AR
    When I installed new knock sensors in the 5VZ over 5 years ago, I think I used SMP Intermotor that I most likely bought from Rock Auto. Toyota OEM knock sensors are crazy expensive -even with me finding them at 30% off.
  13. Dec 15, 2024 at 12:49 PM
    CS_AR
    I think I figured out a way to test a Toyota KS before installation. I dropped and ruined a Nissan KS roughly 10 years ago. I didn't realize it was bad until after I had gone through the pain of installing it.
  14. Dec 15, 2024 at 1:02 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  15. Dec 15, 2024 at 1:04 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  16. Dec 15, 2024 at 1:07 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Anyone with 2GR experience ever dealt with a P0441 and P0455 cel?
    They’re evap codes, already replaced the vacuum lines, gas cap and evap purge valve to no avail..
    Driving me insane :frusty:
  17. Dec 15, 2024 at 1:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  18. Dec 15, 2024 at 1:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ordered it, a knock sensor and some weird connector/controller part.
    Figured if I'm going back in, I'll replace knock sensors and wiring as well.
    Then I can implement Zane's method for the heatshrink on the connector for the starter.
  19. Dec 15, 2024 at 1:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Those soft hands not helping any? :luvya:
  20. Dec 15, 2024 at 1:53 PM
    time623
    James
    AZ
    Not at all, these hands are for white work not blue work yk
    Kwikvette[QUOTED] likes this.
