  1. Dec 23, 2024 at 8:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  2. Dec 23, 2024 at 10:42 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I've been looking at a 2000 Tundra TRD 4x4 today. It is stock and well-maintained at 177,000. I found an idea for what I would do with it. Always dealer-maintained. I would buy it from a Toyota Tech, the 2nd owner.
    Recent timing belt, water pump, starter. All maintenance is from the same dealer. Local truck.
  3. Dec 23, 2024 at 10:53 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
  4. Dec 23, 2024 at 11:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What about Boost and 33s? Asking for a friend. :pray:
  5. Dec 24, 2024 at 6:03 AM
    Wulf
    rock raisin
    i think you'll be alright, you got driver mod:D
    Digiratus[QUOTED] and TacoVio like this.
  6. Dec 24, 2024 at 8:03 AM
    CS_AR
    I remember figuring out these Vacuum lines something like 10 years ago. The 98 models have a bunch of vacuum lines and complicated EGR setup and became incredibly simple in 99 with an electric EGR.
    A buddy from FL sent me this diagram to save me.
  7. Dec 24, 2024 at 9:31 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
  8. Dec 24, 2024 at 9:57 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Maybe I've just been lucky. :notsure: 265K and still on original electronics and engagement motor. As for gear sets, maybe regearing to 4.88s is the difference.
    TacoVio likes this.
  9. Dec 24, 2024 at 9:59 AM
    Digiratus
    Roaming the PNW
    The RedHead
  10. Dec 24, 2024 at 10:11 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well, Lexus is refunding me for sending me the wrong parts.
    So now I've got steering knuckle shims and a seal driver for an 80 series I don't own :laughing:
  11. Dec 24, 2024 at 10:12 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Are they all 80s parts? I'll buy em from ya, I have a front end rebuild coming up again
  12. Dec 24, 2024 at 10:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Eh you can have them; I'll ship them out Thursday?
    It's Joey's seal driver kit I bought awhile back, never used. And the shims are these here -
    Part number came back to an 80 series.
    Wulf likes this.
  13. Dec 24, 2024 at 10:17 AM
    Speedytech7
    Yeah they look like a full set of trunion shims, thanks dude! Mine were borderline last time I did the rebuild but at the time they were out of shims in US stock and I let mine ride.
    Wulf likes this.
  14. Dec 24, 2024 at 10:22 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Think I've also got that power steering saver thing somewhere if you want it.
  15. Dec 24, 2024 at 10:24 AM
    Speedytech7
    Sure, can't hurt. My power steering started leaking a year ago pretty bad. I've just let the whole thing leak at this point, not a single well sealed but anymore on that engine haha
    Kwikvette[QUOTED] likes this.
  16. Dec 24, 2024 at 11:12 AM
    Wulf
    rock raisin
    you don't take out the shims for nice and tight steering??? :luvya:
    Kwikvette likes this.
  17. Dec 24, 2024 at 11:14 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Some people swear by the Lucas oil stop leak for power steering stuff. It didn’t seem to do much for me though.
  18. Dec 24, 2024 at 11:16 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Or, you could just rebuild your power steering pump instead of using magical leak stoppers in a bottle :burp:
    Mine leaked worse than it originally did when I replaced all the old low pressure lines, which lead me to replacing the high pressure line and rebuilding the pump with new seals
    Guy on mud did an entire walk-through on how to
  19. Dec 24, 2024 at 11:19 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I remember the HP hose being like $1000 from Toyota. The Gates equivalent was a small fraction of that though.
  20. Dec 24, 2024 at 11:20 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What? No.
    It was only like $150 give or take?
    But I did also go with a Gates hose for less.
    Still, you're too obsessed with bottle miracles.
