  1. Feb 1, 2025 at 9:08 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I considered it. I'd have to buy a bit to modify anyway, so I'd rather just buy what I need if I can, but...
    I have access to a lathe at work (I'm not certified to use it myself, but I could probably find someone). How easy/difficult is it to work the steel used in a typical hex bit?
  2. Feb 1, 2025 at 9:09 PM
    6P4
    Colorado Springs
  3. Feb 1, 2025 at 9:10 PM
    turboTacoMonkey
    turboTacoMonkey Well-Known Member
    2000 Turbo Taco SR5 MT
    TBD
    replace the bolt...
  4. Feb 1, 2025 at 9:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I too vote getting a hole drilled.
    Especially on a lathe that'd be fast and easy as hell.
    Tools typically used hardened steel but carbide tooling should work on it.
  5. Feb 1, 2025 at 9:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  6. Feb 1, 2025 at 9:16 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It would be pretty easy on a lathe, I'm sure somebody there has a center hole drill, then just control your feed with the tailstock. A good high speed steel drill will still drill tool steel. Wow that's a tongue twister
    6P4[QUOTED] likes this.
  7. Feb 1, 2025 at 9:17 PM
    6P4
    Colorado Springs
    Not sure that's viable.
    Some context...
    The bolt is part of a cam assembly to hold a bike rack into a hitch receiver. I doubt it's a standard bolt, although I can't say I've even considered taking the cam assembly apart.
    The security hex is supposed to discourage people from stealing the rack. That's also why 1up doesn't publish the fastener spec and why they want proof-of-owernship of a rack before selling the tool
    Of course, it's not that hard to figure out what size tool you need and buy/fabricate one, so I have an additional lock to secure things.
    I have two of the original 1up L-wrenches, I'm just looking for something more convenient.
  8. Feb 1, 2025 at 9:18 PM
    6P4
    Colorado Springs
  9. Feb 1, 2025 at 9:19 PM
    turboTacoMonkey
    TBD
  10. Feb 1, 2025 at 9:19 PM
    turboTacoMonkey
    TBD
    curious on the driver for 3/8 driver. lol.
  11. Feb 1, 2025 at 9:23 PM
    turboTacoMonkey
    TBD
    it is interesting how that is an odd combo to find; can find about everything else in 3/8 drive...
  12. Feb 1, 2025 at 9:23 PM
    6P4
    Colorado Springs
  13. Feb 1, 2025 at 9:25 PM
    6P4
    Colorado Springs
    Another option I'm considering: Take a 3/8" security L-Wrench, cut the working end off, and epoxy/JBweld/whatever it into a regular 3/8" socket.
  14. Feb 1, 2025 at 9:26 PM
    Speedytech7
  15. Feb 1, 2025 at 9:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Could drill into the socket wall and tap it to add a set screw in there to hold it in place
  16. Feb 1, 2025 at 9:30 PM
    6P4
    Colorado Springs
    CS_AR likes this.
  17. Feb 1, 2025 at 9:32 PM
    turboTacoMonkey
    TBD
  18. Feb 1, 2025 at 9:33 PM
    turboTacoMonkey
    TBD
    but ya - looks like if you want 3/8 3/8 - you drillin.
    6P4 likes this.
  19. Feb 1, 2025 at 9:35 PM
    6P4
    Colorado Springs
    Thanks for playing, everyone.
  20. Feb 1, 2025 at 9:38 PM
    6P4
    Colorado Springs
    Not sure why I didn't do this earlier, but I just checked... even McMaster and Grainger don't have 'em.
