  1. Feb 18, 2025 at 7:30 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Too casually clearly. Certainly an interesting project though, making an intake. I'm glad we are only designing for top end power here, have a feeling actually making a well rounded intake manifold to take advantage of a certain range of an engines power would be super difficult. I don't think I would know the math to figure out plenum volume and runner length to the extent that Toyota did for example (I can do the general longer means lower torque guesstimation)... and maybe now with VVT Toyota's intakes have gotten lazier, their stock plastic ones don't seem nearly as intricate anymore.
  2. Feb 18, 2025 at 7:34 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Most of them still have an ACIS feature creating variable plenum volume to change the pressure wave characteristic for torque and power, a feature I kept... and more simple but basically the same as earlier TVIS concepts that varied runner length
  3. Feb 18, 2025 at 7:38 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I also kept the entire runner portion of the OEM Manifold... so to say I printed the whole manifold is misleading, just the Plenum/TB neck
    Speedytech7[OP] likes this.
  4. Feb 18, 2025 at 7:42 AM
    Speedytech7
    Kwikvette likes this.
  5. Feb 18, 2025 at 8:10 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  6. Feb 18, 2025 at 8:30 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    As someone who follows aviation pretty closely, and yes there is a general cadence of GA accidents, the uptick in commercial incidents is notable. Still, it is the safest way to travel, so I wouldn't worry much. As long as it's not a Boeing at least.
  7. Feb 18, 2025 at 8:33 AM
    Speedytech7
    Averages are dangerous this way... overall yeah probably very safe, especially when looked at in a short-term lens like 10years... but looked at in the relevant short-term lens of 2025... I might pass for the remaining 3.88yrs
  8. Feb 18, 2025 at 8:41 AM
    m3bassman
    Green truck
    I understand the sentiment but let's be clear, correlation is not causation. The Bering Air flight stalling in icing conditions on approach, the suspected yaw damper malfunction in Philly, the Blackhawk failing to see and avoid the CRJ, and the hard landing in Toronto, are not related directly to anything that has changed in the last month.
  9. Feb 18, 2025 at 8:45 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I haven't watched any recent news regarding the Blackhawk incident, but the speculation made by 3rd parties seems far more plausible than anything anyone else has officially shared. Again, I haven't seen anything in a few weeks so I don't know if anything else has officially been stated.
    Most convincing one seems to be that the BH pilot acknowledged the aircraft mentioned by air traffic control, but had mistaken it for the plane that had just departed and not the one that was going to land.
  10. Feb 18, 2025 at 8:46 AM
    Speedytech7
    Fly safe then... what a funny thing to say to someone really as if they could have any effect on the flight at all as a passenger.
  11. Feb 18, 2025 at 9:09 AM
    eon_blue
    Azusa, CA
    There's a good Swindled podcast on that whole thing if you listen to podcasts
    https://open.spotify.com/episode/1rHZVwgFpTLF6PGKtC7ypk?si=520abb2c06834413
    What I find interesting is just how confident the owner of it all was knowing full well the shortcuts he was taking...I mean it would be one thing if he was doing that and then sending people down there while he watched from above, but that crazy fucker was captaining that death trap himself every time. It's wild the level of denial that gets brought on by sheer unhinged narcissism
    Kwikvette[QUOTED] likes this.
  12. Feb 18, 2025 at 9:10 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Kid goes down for a nap in 2 hours; I'll give it a listen for sure!
    eon_blue[QUOTED] likes this.
  13. Feb 18, 2025 at 9:10 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    So I'm leavin to go camping/wheeling on Friday. Do I send the LCA bushing and UCA job after work today and the rest of the week or am I setting myself up for disappointment with no time if shit inevitably goes sideways
  14. Feb 18, 2025 at 9:12 AM
    eon_blue
    Azusa, CA
    I don't know about the bushings (never done them but sounds pretty straightforward unless they're seized)...but UCAs are easy peasy, just give yourself time for an alignment after all that.
  15. Feb 18, 2025 at 9:13 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Opposite here - did LCA bushings twice and found it to be pretty easy.
    Granted, I used the bottle jack method to pop out my old bushings and it seems to be a hit or miss for folks here.
  16. Feb 18, 2025 at 9:13 AM
    eon_blue
    Azusa, CA
    I'm hooked on that podcast, I don't know what it is about that host dude's voice but it's soothing AF to hear him narrate wild stories of fraud and deceit lol
  17. Feb 18, 2025 at 9:14 AM
    time623
    James
    AZ
    Is a ball joint press an option for the bushings as well? Bit nervous about bending something with the bottle jack method. And I'd have to go buy a bottle jack, would be a good thing to have but still
  18. Feb 18, 2025 at 9:16 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You can try torching them, as it's another option I've seen done by others.
    Don't ruin your trip, just do it all after you get back.
  19. Feb 18, 2025 at 9:24 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
  20. Feb 18, 2025 at 9:28 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tour991[QUOTED] likes this.
