  1. Feb 21, 2025 at 9:58 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I’m so mentally ill I bought the special coolant grade FIPG for the coolant bypass tube when I was doing the engine in my 04.
    That shit was like $80 and I used 1% of the tube.
  2. Feb 21, 2025 at 10:25 PM
    eon_blue
    Azusa, CA
    I’ll let you know what the view from over the hill is like so you know what to expect a few months later
    CS_AR likes this.
  3. Feb 21, 2025 at 10:46 PM
    Running Board Man
    Running Board Man Well-Known Member
    I'm that way when it comes to bolts with mismatched heads
    I will drive 40 minutes to a junkyard to get the "right" bolt
    I'm soo mentally ill I think finding a better job will cure depression
  4. Feb 22, 2025 at 5:19 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Going to the junkyard seems more like a good way to fight depression though.
    CS_AR likes this.
  5. Feb 22, 2025 at 5:44 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    That UTE Ltd bed is what I'm going with if I ever get the gumption to go for it.
    04Pre_Runner[QUOTED] likes this.
  6. Feb 22, 2025 at 10:17 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    You don't really notice until after you turn 41. Then you are forty something. However, fifties are fabulous.
    jubei and Tour991 like this.
  7. Feb 22, 2025 at 10:22 AM
    CS_AR
    You're right. I need to make a trip to pick up some OEM spring hose clamps, and assorted JIS spec nuts, bolts, and screws. No chance of finding any Toyotas around here. Once in a great while a 2nd or 3rd gen 4Runner will turn up that had been sitting for 20 years and has vegetation growing in it.
  8. Feb 22, 2025 at 10:29 AM
    CS_AR
    15 years ago, I used Permatex Ultra Grey to seal up a VH45DE -- the gasket less engine. Valve covers and coolant passages all use RTV instead of gaskets. It's still holding and dry as a bone today.
    I love Toyota FIPG and actually use it on Nissans today. But I can't complain about Permatex Ultra Grey or conventional black. I did have some of "The Right Stuff" let me down where I should have been using Ultra Grey.
  9. Feb 22, 2025 at 10:32 AM
    CS_AR
    You'll be able to burn the back tires off of that with a lightweight bed like that one.
  10. Feb 22, 2025 at 10:33 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    This came up for 3k locally so I jumped on it. I've always kinda had thing for these after looking at them in the showroom when they were new when I was a little kid. It's 5 speed 4x4, 177k miles, with the head gaskets, timing belt, and most engine seals having been recently replaced. It seems to run really smooth. I'll probably just use it for camping and exploring forestry roads.
    Kwikvette, 6P4, 01x4 and 2 others like this.
  11. Feb 22, 2025 at 10:35 AM
    CS_AR
    I need to get a new chair to use in the driveway and garage while I work on projects. The chars I have tried from HF usually tip over or the wheels break off. I'm ashamed to admit that I'm using the bottom half of an old office chair where the back broke off something like 10 years ago. It has 5 wheels that keep it sturdy. While it is trashy looking, it is lightweight and I can maneuver it around easily.
    Kwikvette[QUOTED] likes this.
  12. Feb 22, 2025 at 10:39 AM
    CS_AR
    Nice! Long live the X. Some automatics met an early grave due to the Strawberry Milkshake of Death (SMOD) where the ATF radiator nipples corroded due to dissimilar metals. Hondas had the same issue. The 5MTs never had that issue.
  13. Feb 22, 2025 at 10:44 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Yea it'd make a good beater for the Ozarks. No worries about pinstripes, it's kinda fugly already!
    CS_AR[QUOTED] likes this.
  14. Feb 22, 2025 at 11:23 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    42 was the year all the dumb things I did started catching up with me. Mid 40s have been awesome besides always being sore.
    jubei likes this.
  15. Feb 22, 2025 at 11:33 AM
    6P4
    Colorado Springs
    I don't see anything to be ashamed about there. It works and it's paid for.
  16. Feb 22, 2025 at 11:34 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'll post it once I get it cut and made.
    I'd even be willing to make the cut out parts if you want to weld them together.
    Tour991 and CS_AR[QUOTED] like this.
  17. Feb 22, 2025 at 11:36 AM
    6P4
    Colorado Springs
    I've already collected almost all of the useful parts I can hope to find in the junkyard here. Kinda disappointing to not have as much reason to go anymore. Hopefully I'll be there tomorrow helping a friend look for an OEM radio and wheel for her 4Runner.
  18. Feb 22, 2025 at 11:36 AM
    CS_AR
    Narrow with a short turning radius. A hidden gem.
  19. Feb 22, 2025 at 11:37 AM
    Tour991
    James
    South Reno/Tahoe
    I would definitely be interested in buying one from you.
    CS_AR and Kwikvette[QUOTED] like this.
  20. Feb 22, 2025 at 11:38 AM
    CS_AR
    I'm going to do this rear spring flex mod. It's not that hard to incorporate 80 series mods on a 100. This is more like my terrain.
    481247703_1281155482952705_6714798508524_539b20e0675a075d255cd871370ba9f059b71603.jpg
