  1. Mar 5, 2025 at 9:42 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Thats pretty bad :rofl:
  2. Mar 5, 2025 at 9:57 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah she's about cooked. I wish the seals in there were eassy to change but they're square cut teflon
    TacoVio[QUOTED] likes this.
  3. Mar 5, 2025 at 10:06 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    An Armanda
  4. Mar 5, 2025 at 10:14 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    uhoh that stuff is aggressive lol
    i have had good luck adding high mileage 10w30 to swell hydraulic/steering seals. worked on my ifs box and trailgear ram til i rebuilt jt
  5. Mar 5, 2025 at 10:17 AM
    Speedytech7
    I will probably use some HI-MI MaxLife ATF with the new pump and I'll change the lines and reseal my pump again.
  6. Mar 5, 2025 at 10:18 AM
    CS_AR
    I put a lot of miles and Colorado mountain trails on my old 25 year old Toyotas that most people with new vehicles will not even consider.
    Fly across the country running 90 MPH to go run Black Bear and live the wild life in the mountains and them back again on a straight through 17 hour run.
    You can't do that with just any vehicle.
  7. Mar 5, 2025 at 10:27 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Thank you sir. :hattip: Just picked up a set of LBJs.
    $189 for a set.
    CS_AR[QUOTED] likes this.
  8. Mar 5, 2025 at 10:35 AM
    Speedytech7
    Yeah that's not a bad price at all, saw as low as $174... Just depends on what online dealer you like
  9. Mar 5, 2025 at 10:36 AM
    Wulf
    rock raisin
    i have had decent results with that in the tacoma. stopped a few seeps and it is heat resistant enough to last a year or two before getting burned lol
  10. Mar 5, 2025 at 10:41 AM
    Speedytech7
  11. Mar 5, 2025 at 10:44 AM
    Speedytech7
    It's the only Synthetic Dex 6 I've seen act right in DexIII applications
  12. Mar 5, 2025 at 11:05 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    after I get some miles on it and confirm it holds up I might make the file available.
  13. Mar 5, 2025 at 11:29 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Even better
  14. Mar 5, 2025 at 12:32 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I'm still sad Black Bear was closed when I was there last year. I was a bit suspicious when traffic was going both ways on a one way trail
  15. Mar 5, 2025 at 12:37 PM
    Wulf
    rock raisin
    well, he pulled enough people into it to get something out of it. i know of at least one person (not even me:luvya:) who complained to his manager about how hostile he was handling it lmao
  16. Mar 5, 2025 at 12:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Man big congrats to Charlie Daniels for winning in the Baby Kid Swing Pick Up Truck Class at Weaber Valley Speedway
    Dude's a legend :bowdown:
  17. Mar 5, 2025 at 1:14 PM
    Wulf
    rock raisin
    for dale
    jubei, time623 and Digiratus like this.
  18. Mar 5, 2025 at 1:21 PM
    benson winkleberry
    benson winkleberry Well-Known Member
    ‘00 taco 2.7 4x4 MT
    wholesome
  19. Mar 5, 2025 at 1:51 PM
    Speedytech7
    Huh, I just listened to a BBC In Our Time podcast about Descartes and they used this portrait (minus the AI expansion) so this is particularly hilarious to me
    Kwikvette and Wulf like this.
  20. Mar 5, 2025 at 2:12 PM
    Wulf
    rock raisin
    hm…would? lol
