  1. Mar 18, 2025 at 10:40 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    100pct all the time, it would make a good space heater if you didnt already live in the desert
    Kwikvette[QUOTED] likes this.
  2. Mar 18, 2025 at 10:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tell me it has Winamp! Pretty sure I got it from you when I asked around
  3. Mar 18, 2025 at 10:41 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    My family had an ME PC briefly. It included a free upgrade to XP as soon as it was available.
  4. Mar 18, 2025 at 11:00 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It was a version we completely glossed over in my household growing up. We had Win 98 on a pretty nice compaq Presario multimedia PC for probably longer than would be advisable and then switched to an HP Pavilion with Windows XP sometime around 2002.
    Honestly it's the worst of both worlds, Win ME is based on Win9x codebase and is super legacy essentially still having a DOS backbone. Win NT 4.0 and Win 2000 had already been out forever and were fully compatible with all Windows applications and had a good DOS compatibility layer built in. Like why would you make one more Win9x based thing when you already knew all the drivers and applications would be leveraging WDM and NT? Win ME could have been a great way to ease people into all the new backbones with old styling still.
    CS_AR likes this.
  5. Mar 18, 2025 at 11:03 AM
    Speedytech7
    I've got all the old versions of stuff. I can show you how to setup the inode to use the old Internet if you want. You can even still use Winamp on old computers and stream current streams
  6. Mar 18, 2025 at 11:24 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fired up the old rig
    I forget how noisy these can be
  7. Mar 18, 2025 at 11:26 AM
    Speedytech7
    I swap fans in my old stuff to help with that a bit, I don't mind the spinning hard drive noises but fans from over 10yrs old are usually in need of lubrication and get loud. The Vantec Stealth fans are old style but super quiet.
  8. Mar 18, 2025 at 11:28 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    These bad boys are Noctua, it's actually the air cooler I forgot about that's louder than my AIO :rofl::bananadead:
    I'll probably get it to roar once I open up Fusion and play with it a bit
  9. Mar 18, 2025 at 11:30 AM
    6P4
    Colorado Springs
    According to the Wikipedia history, it wasn't supposed to exist. Windows 98SE was supposed to be the last 9x system, followed directly by XP, but XP's schedule slipped enough that management panicked and tried to fast-track another 9x-based system to avoid going too long between new OS releases.
    ME was only in the market for a year before XP became available, so I'd wager it was a net loss to Microsoft between bad press and wasted energy/resources.
  10. Mar 18, 2025 at 11:31 AM
    Speedytech7
    That thing won't have any issue with fusion, won't use both cards, probably wont even use one card much at all, but that computer isn't wildly out of date really. Fusion is pretty low end in terms of their use of modern CPU instruction and GPU instruction set encoding. It really is designed to work with some seriously low end systems. As long as that CPU has SSE 4a I bet it works, hell Fusion might not even need 4a it might only need 3
  11. Mar 18, 2025 at 11:33 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Being free, I can see how they gotta keep resource utilization low
    Solidworks must be a bit more challenging?
  12. Mar 18, 2025 at 11:37 AM
    Speedytech7
    SolidWorks used to be really bad on resource usage... I'm not sure if computers got exponentially better or they just finally wised up and started using the GPU compute features of consumer cards more. SolidWorks use to deny you GPU compute and rendering on consumer cards, would only enable those enhancements with a FireGL or Quadro vector card back in the day. So anything more than a simple 3D part or a small 3D assembly would bog down the display really bad. But now it seems to work really well with consumer grade nvidia cuda and whatever AMD rebranded their compute library as. I can still bog it down but it takes a pretty big assembly to do it.
  13. Mar 18, 2025 at 11:41 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ahh the good ol' Quadro cards
    Those fuckers were always jam packed with twice the vram as their consumer grade variants
  14. Mar 18, 2025 at 11:43 AM
    Speedytech7
    Yeah and back in the day the CUDA cores were totally unlocked on those Quadros to do compute tasks and the consumer cards could only use the CUDA stuff for PhysX and DirectX/OpenGL rendering. That's probably why SolidWorks didn't work with them but honestly even using 1/3 of the CUDA core power (that's all they could used for non approved compute tasks) on a consumer card would have been better than CPU rendering everything.
  15. Mar 18, 2025 at 11:57 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    For an old rig, it opens and runs CAD just fine!
    As for CAM, it uses a BIT more resources for simulation and CAM otherwise damn even a poor computer can run it :rofl:
    That's 4th Gen goodness right there
    And only on DDR3, it still only used 8gb
    GPU usage is really just for rendering/simulation so I did expect a little usage here
    I just didn't think the second GPU would be used at all damn
    Realistically though, we can ignore all that RAM usage due to stuff in the background like Steam.
  16. Mar 18, 2025 at 12:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah, the resource usage barely changed when Fusion was closed vs opening and running a simulation :rofl:
    Aside from free, no wonder it's wildly popular.
  17. Mar 18, 2025 at 12:08 PM
    eon_blue
    Azusa, CA
    baby foot toe beans :angrygirl:
  18. Mar 18, 2025 at 12:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    My main PC is the only one that's got a pic of the little dude as my background, not the rest though since they're expendable
    Fuck kids grow up fast :(
  19. Mar 18, 2025 at 12:17 PM
    eon_blue
    Azusa, CA
    Yeah their little feet are cute until they start walking and wearing shoes all while refusing to wear socks and when the shoes come off at the end of the day those little feet become means of biological warfare
    I had to start sneaking foot powder into Sofia's shoes
    Tour991 and Kwikvette[QUOTED] like this.
  20. Mar 18, 2025 at 12:17 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Windows NT bring back memories of Dave Cutler, Lou Perazzoli, and the VMS boys from DEC in Maynard MA. I loved that OS.
