  1. May 1, 2025 at 8:51 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Ooh, that'd look good with one of Nomads models. grey Convoy or silver Touring would be nice imo
    https://www.nomadwheels.com/collections/truck-suv/products/501-convoy-utility-gray
    https://www.nomadwheels.com/collections/truck-suv/products/505oe-touring-oe-silver
    CS_AR[QUOTED] likes this.
  2. May 1, 2025 at 8:58 AM
    01x4
    @6P4 @Sperrunner
    Washy wash. Need to get that sticker off without messing up the clear. Clean components, etc.
    Cheaper than buying vehicles...
    Nitto cockpit bits, grips, 1x chainring, seat post, saddle, new cables and go. The older gentleman I got it from even put new tubes in.
    After looking a bit, seems like the pink/blue is one that gets built a lot these days, must be more common than other colorways.
    jubei likes this.
  3. May 1, 2025 at 10:44 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Those look nice and low maintenance. Rays has a new OBX series for Toyota. I hope they weigh about 16 lbs like TE37s. I'm looking to stay at 18.6 LBS or lighter.
    https://www.rayswheels.co.jp/en/products/brand/detail/262
    01x4[QUOTED] likes this.
  4. May 1, 2025 at 10:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Stuff grows so fast
    Nematodes move too fast to capture, but here's some cyanobacteria
    unstpible and CS_AR like this.
  5. May 1, 2025 at 10:49 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    1x is nice if you're staying flat, but I do occasionally miss riding a triple crank, preferably on a touring build with bar-end shifters.
  6. May 1, 2025 at 10:57 AM
    Wulf
    rock raisin
    how is the flavor ??
    unstpible likes this.
  7. May 1, 2025 at 10:58 AM
    Wulf
    rock raisin
    against my better judgement i think i am going to consider a ford elocker. at least its 12v on/off unlike the dumb toyota bs
  8. May 1, 2025 at 11:01 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :puke:
  9. May 1, 2025 at 11:02 AM
    Wulf
    rock raisin
    that might be an accurate way to describe the taste test result too :luvya:
  10. May 1, 2025 at 11:24 AM
    CS_AR
    Considered Eaton ? I remember it is stupid simple to install and test with 12v.
  11. May 1, 2025 at 11:27 AM
    Wulf
    rock raisin
    my locker options for the sterling are pretty limited so its off the table, but I am not really interested in the Eaton offerings. If not the ford locker I would be stuck with an OX or ARB which are both 2-3x the price of the ford one lol
    the ford locker doesnt have the lock/unlock issue that the old eatons did and is also stronger. Was planning to leave the rear welded but the gf hates it. she was cringing hard at the tire chirp and hop lol
  12. May 1, 2025 at 11:29 AM
    Wulf
    rock raisin
    used to like the detroit lockers but i dont see the upside over a lunchbox locker unless super concerned about carrier/ring gear deflection. somehow lunchbox lockers are better at surviving a broken shaft than the detroits are lol
    picked up a torq locker for the front, made in usa and the 2 spring design is a lot easier to install/remove than the typical lunchbox locker design
    Running Board Man likes this.
  13. May 1, 2025 at 11:34 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Yea I’m working on it. I may have to drive 3-4 hours to go get it but I think it’s worth the try. I confirmed it’s from a 3.4 too. I don’t see a reason why my gearbox itself shouldn’t still work with a new bell housing. I was able to shift though all the gears and shift into 4x4 in neutral, it’s just the clutch pedal that wasn’t doing anything.
    CS_AR likes this.
  14. May 1, 2025 at 11:37 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Send it
  15. May 1, 2025 at 11:43 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just go get it.
    Less excuses, more doing.
    3-4 hr drive goes by quickly.
  16. May 1, 2025 at 11:52 AM
    Wulf
    rock raisin
    3-4 hours? little bit of car karaoke, maybe an audio book, little bit of dissociation, boom, there in no time
    jubei and Kwikvette[QUOTED] like this.
  17. May 1, 2025 at 11:54 AM
    01x4
    Agreed, I like 2x as well as 3, but we're so flat here you have to go out of your way, like into the state park, to find some fun hills, so I thought I'd try a simple setup. At least I have the parts to throw on if I want more. I still haven't tried the Bosco bars, thought this might be a contender.
    6P4[QUOTED] likes this.
  18. May 1, 2025 at 12:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I don't see the issue, or why the judgement
    Just go pick it up like any traditional FB purchase
  19. May 1, 2025 at 12:01 PM
    Spicoli67
    Spicoli67 Well-Known Member
    01 ext cab
    I’ve got a super duty tow pig. Been eyeballing the torq lockers. For the price if they work I think they’ve gotta be the best.
    But I’ve been secretly hoping to find a blown 6.7 with an e locker so I can convert the front to coils and an e locker and longer leaves.
  20. May 1, 2025 at 12:10 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    That sounds like a political statement
    time623 likes this.
