  1. May 17, 2025 at 1:32 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    dont slander the fent fiends, they worked hard on that. Hard to put shit together when you're bent over half conscious
    eon_blue[QUOTED] likes this.
  2. May 17, 2025 at 1:35 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Dibs on the house
  3. May 17, 2025 at 2:48 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Oh wow
  4. May 17, 2025 at 3:27 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    We are all just a broken bolt or galled nut on a stud away from a really shitty day....
    Running Board Man and Sperrunner like this.
  5. May 17, 2025 at 3:31 PM
    Speedytech7
    Just a normal day
    Running Board Man likes this.
  6. May 17, 2025 at 3:53 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Topside creeper for the win. Made all of my underplenum work possible. The only downside is storing it in the garage for occasional use.
  7. May 17, 2025 at 4:45 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I can face time you and tell you that your doing it wrong
  8. May 17, 2025 at 5:27 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Annoyed as heck.
    Had to replace the manifold x turbo gasket on the mr2, and re fastening the 4th stud, fucking nut galls, and of course its the hardest one to get to...
    Need to 2gr swap this boi soon.
  9. May 17, 2025 at 5:28 PM
    Speedytech7
    I didn't even know you had an MR2
  10. May 17, 2025 at 6:03 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    :boink:
  11. May 17, 2025 at 6:59 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    time623 likes this.
  12. May 17, 2025 at 7:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Overpriced.
  13. May 17, 2025 at 7:08 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Damn, a 'Mexican navy training vessel' hit the Brooklyn Bridge.
    Fortunately just a few injuries but damn it was tall as hell to hit that bridge.
  14. May 17, 2025 at 7:08 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I have no idea what that'd be worth. A grand even maybe?
  15. May 17, 2025 at 7:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    With the plasma cutter, about $1,200 but the table alone about $1,000.
    They come up from time to time in the FB group and really, you'd be better off just making your own.
    It uses a basic Mach 3 controller, lacks Z-axis so no THC, and if purchased for the components themselves, is a rip as you could source everything on Amazon.
    I think it's like $40 for a PSU, between $20-30 per motor (2), any Mach 3 controller, and drivers (2) that run about $11 each. Buy some square tube, and weld up your own frame and choose the movement style of your choice.
    Nice thing is, Mach 3 allows the end user to controller movement/steps depending if you're running a lead screw, ball screw, rack and pinion, or whatever you choose to use. It also has no limits when it comes to table size and all you'd need to pay for is a license to use Mach 3.
    If it were the model that used Firecontrol, and if it came with the Z-axis setup, then it'd be worth about $1,500+ alone as it'd give you all you need to make some quality cuts on a super easy to use program with no licensing.
    TACOTU3 likes this.
  16. May 17, 2025 at 7:39 PM
    TACOTU3
    Had a super fun afternoon playing with the new equipment :welder: IDK if it’s more attributable to the welder or the hood, but night and day difference between the two! Made some leg extensions for my welding table.
    I can’t overstate how EASY everything was today. I could see everything really clear, was able to put weld exactly where I wanted it and had great control of the puddle.
    End result is an extra 6” so I don’t have to hunch if I’m standing and not a single weld I feel inclined to grind! Amazing how much faster everything goes when you’re not grinding up a huge mess…
    time623, Kwikvette and Wulf like this.
  17. May 17, 2025 at 7:39 PM
    Wulf
    rock raisin
    welp after crying about spending $150 on parts washer solvent… its all done and filled
    reclaimed the wheel bearings and races and dumped them in there to soak. thats about all i had energy for today.
    seeing a new dr on monday hopefully they can figure out wtf is wrong with me so I can have energy again
  18. May 17, 2025 at 7:40 PM
    Wulf
    rock raisin
    looking much improved
    a good welder and mask are both well worth it. @Kwikvette has tried out quite a few and will agree that im right:p
  19. May 17, 2025 at 7:42 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I found when i stop zyning awhile before bed i slept better. When i would fall asleep with one in i would sleep like shit
  20. May 17, 2025 at 7:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh, you OWE it to your eyes (and lungs) to spend a little more on the good stuff
    TACOTU3 likes this.
