  1. Jun 10, 2025 at 11:36 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Stephanie says that all the time, she'd love my beard to be super short or gone :bananadead:
  2. Jun 10, 2025 at 11:37 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Those videos where dad's reveal a shaven face to their kids is hilarious - it stresses them the hell out to "hear" their dad the way they recognize him, but looking totally different
    Wulf likes this.
  3. Jun 10, 2025 at 11:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I totally wish I knew how to code
    I understand the extreme basics of what would be needed, but wouldn't know all the code for how to execute said commands
    Much less have access to the software to modify it since its under lock and key
    I wish my CNC table's software had a pierce counter, which would be easy to implement since it just needs to count how many times M03 is detected in the G code as it's running
  4. Jun 10, 2025 at 12:30 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Does the software output any kinda logs, even to a internal console or anything like that?
    Wouldn't be hard to wire up some automation to hook the native controls and get the content and then count whatever occurrence of a string value is in there... I could almost write the ChatGPT prompt for you :rofl:
    Speedytech7[OP] likes this.
  5. Jun 10, 2025 at 12:31 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Why can't we just have simple manual transmissions that last forever anymore
  6. Jun 10, 2025 at 12:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The software itself is under strict lock and key, considering it is specifically written to their own proprietary controller.
    However, you're always welcome to come over and add whatever doohickey or whatchumacallit to my thingamajig for counting each pierce!
    I never considered an "external" counter so you could be onto something.
  7. Jun 10, 2025 at 12:50 PM
    eon_blue
    Azusa, CA
    because how am I supposed to text and drive and shift at the same time
    272k on the 4runner's OG manual trans. I expect the engine will give out long before the transmission does
  8. Jun 10, 2025 at 12:53 PM
    eon_blue
    Azusa, CA
  9. Jun 10, 2025 at 12:55 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Technically since it's controlling a CNC it is outputting serial commands. Can sniff that for G03 output and count it with a PS script pretty easy.
    jubei likes this.
  10. Jun 10, 2025 at 1:00 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So real talk - on the hardware side, I think the simplest solution would be to tap into pins 1 and 2 (using those numbers as an example) on the wiring between the plasma cutter and CNC controller because all it does is open and close the circuit.
    Would I be correct to assume that to be the least intrusive method?
    From there I guess I would just need to figure out what to use to read said inputs. Do I need to go as much as getting a raspberry pi for this? I'm a complete novice to micro anything if we're gonna make this happen.
  11. Jun 10, 2025 at 1:02 PM
    Speedytech7
    I mean I could do that way with an Arduino I suppose pretty easy. How do you load commands into this machine?
  12. Jun 10, 2025 at 1:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The software for the controller contains not just the means for reading said g-code to run the table, but also handles the CAM side of things.
    I no longer use Fusion for my CAM as it's all seamless now. All I do is bring over my DXF to it.
  13. Jun 10, 2025 at 1:06 PM
    Speedytech7
    Oh that's interesting and maybe a bit limiting if you cant manually adjust the cut path. I guess if it's processing it all in one then there's no computer putting out commands to sniff. Then yeah Arduino is the way. That would be cake to program though
    Kwikvette[QUOTED] likes this.
  14. Jun 10, 2025 at 1:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Looking at Arduino kits now - only tough part is finding a small case that'll fit with the included display. That display the kit comes with will easily suffice so no need to get fancy.
  15. Jun 10, 2025 at 1:11 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    The old slush boxes on those seem pretty unlikeable too - they were almost too dumb to die.
    Running Board Man likes this.
  16. Jun 10, 2025 at 1:13 PM
    Speedytech7
    Oh I've got tons of Arduino unos lying around, can get a display for you for like $3 haha.
    Wulf and Kwikvette[QUOTED] like this.
  17. Jun 10, 2025 at 1:16 PM
    eon_blue
    Azusa, CA
    I had an auto '99 Prerunner when I was 19 or so, threw it in reverse going ~40mph once by accident. Horrible noise, jerking and the truck stalled but started back up and no issues. Well..there may have been long term, who knows. Only had it a couple years
  18. Jun 10, 2025 at 1:28 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    You must’ve let the intrusive thoughts win
  19. Jun 10, 2025 at 1:31 PM
    eon_blue
    Azusa, CA
    what other kind of thoughts are there
  20. Jun 10, 2025 at 1:48 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Didn't have time to take photos because I was scurrying, but just spent the afternoon cleaning a massive ant nest out of my mom's Outback for her. They'd nested inside the, well they're not really frame rails since unibody, but yeah, in the drivers side one. Anyway, fucking fistfuls of live ants. And eggs. Pulled all the exterior lower trim and pumped windex water into it and flushed a few times. They also scattered into the wheel well so I had to rip that off double quick and more fell out.
    Insult to injury, I was letting it dry and went out to pick up the plastic clips that'd flown around when I was rushing and there was line of the little shits carrying eggs across the driveway back into her car!
    Once again the moral of the story is that ants are assholes. Very impressive, tiny, intrusive assholes.
    CS_AR likes this.
