  1. Jun 28, 2025 at 1:03 PM
    Wulf
    rock raisin
  2. Jun 28, 2025 at 1:08 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
  3. Jun 28, 2025 at 1:20 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    DO the regular cabs and extra cabs have the same size fuel tanks? This one I’m looking at is from an 01 single cab
  4. Jun 28, 2025 at 1:26 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    No
  5. Jun 28, 2025 at 1:35 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Oh shit, so there’s no way to make it work?
  6. Jun 28, 2025 at 1:36 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Iirc mine was 15 gallons
  7. Jun 28, 2025 at 1:37 PM
    Wulf
    rock raisin
    with enough cutting and welding all things are possible, its just metal
  8. Jun 28, 2025 at 1:37 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    This is what it looks like
  9. Jun 28, 2025 at 1:38 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I could still maybe get the one from the guy in Newport though cause that’s an extracab
  10. Jun 28, 2025 at 1:40 PM
    Wulf
    rock raisin
    ratchet strap it to the front of the bed and send it
    my 4runner had the factory tank relocated behind the back seat and it was fiiiiiine
  11. Jun 28, 2025 at 1:43 PM
    eon_blue
    Azusa, CA
    18.5 gallons for the Prerunners and 4x4s. The light comes on at 15 gallons spent. The 5lugs have the 15 gallon tank.
    I thought it was the same size between the extra cab and regular cab as long as they were both 6 lug, but I could be wrong
    time623 and Tour991 like this.
  12. Jun 28, 2025 at 1:45 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I thought some of the early models had smaller fuel tanks but idk for sure. Now I’m reading the 01 and layers had different evap systems which might make even the extra cab tank not a direct fit. Ugh I didn’t realize it was so complicated.
  13. Jun 28, 2025 at 1:45 PM
    Tour991
    James
    South Reno/Tahoe
    Actually they do.
    The difference is in 5lugs and 6lugs. The 5lug has a 15 gallon tank and the 6 lug has a 18 gallon. The difference in the tank is in the depth. The 6 lug tank is deeper at the bottom but the shape is exactly the same and if you use the smaller tank you just need the shorter straps.
    Edit: 95.5 to 2000 tanks are different then 2001 to 2004 tanks. And are not interchangeable
  14. Jun 28, 2025 at 1:51 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Isn’t it just the sender units that are different? I have the straps and sending unit with the tank I just got so I could reuse those. I could try to return this one and go get the extracab tank but I’d rather not go back up there if I don’t have to tbh
  15. Jun 28, 2025 at 2:04 PM
    Tour991
    James
    South Reno/Tahoe
    It's just longer because it sits lower in the tank. If you have everything that is needed for the tank then it will work as long as it's not an 01+ tank.
  16. Jun 28, 2025 at 2:05 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    It is an 01 tank unfortunately. I guess I should try to return/resell it then?
  17. Jun 28, 2025 at 2:09 PM
    Speedytech7
    None of the evap stuff will hook up properly to that unfortunately. you can probably Jimmy rig it tho
  18. Jun 28, 2025 at 2:09 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    the extracab I got the trans and driveline from is also an 01-04 so I guess that wouldn’t work either, RIP
  19. Jun 28, 2025 at 2:10 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Hm yea that doesn’t seem ideal, I’ll se Eid he’ll take it back but it’s my fault for not doing my hw. It was that Evan Knapp guy btw.
  20. Jun 28, 2025 at 2:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You did at least get some parts today?
