  1. Aug 4, 2025 at 6:37 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Not mine, but clean monotones. @01x4 Have you had a Soft Topper?
  2. Aug 4, 2025 at 6:39 PM
    Spicoli67
    Spicoli67 Well-Known Member
    01 ext cab
    You thinking a basic flatbed or one with handy tool boxes distributed about?
  3. Aug 4, 2025 at 6:44 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As basic as possible
    Something like this dude -
    https://www.tacomaworld.com/threads/flatbed-2nd-gens.824293/
    But I'd want to add something to the edges (like a slotted insert or the sort) to be able to slide in some square or rectangular tube in case I need to keep something boxed in or strap down on top
  4. Aug 4, 2025 at 6:46 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Finally got to beer 30
    TACOTU3, Wulf and Kwikvette like this.
  5. Aug 4, 2025 at 6:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Although I still see ads pop up for that one brand that @JKO1998 linked over a year ago for a DIY kit
    Maybe I should look at that again
    Wulf likes this.
  6. Aug 4, 2025 at 6:48 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    dont have many on this phone, maybe a video will do?
    https://youtube.com/shorts/i9eH19hSi74
  7. Aug 4, 2025 at 6:48 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    I was just going to ask, the original plan is for it to be all your own design?
  8. Aug 4, 2025 at 6:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just looking at the kit I mentioned, it sells you the parts so yeah huge pass
    It'll be my own design it seems
    I was only interested cause I thought it was a DXF file pack for cutting your own parts - I would only be interested in the mounting points themselves
    After that, it's just a square frame with crossmembers
    I do like the idea of breaking up the diamond plate into two or three sections with hide-away hinges. This would allow you to create a pocket of storage to put stuff in under the flat bed surface itself.
    time623[QUOTED] likes this.
  9. Aug 4, 2025 at 6:52 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Speedytech7 You mentioned making your own flatbed, and I know your bed has been off several times
    Did you already model up some mounts? If so, I would be happy to buy said files (just the mounts) :anonymous:
    Wulf likes this.
  10. Aug 4, 2025 at 6:54 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    Wulf[QUOTED] likes this.
  11. Aug 4, 2025 at 7:01 PM
    Speedytech7
    Model no, well just give you the measurements if you want them off my flat bed frame.
    Wulf and Kwikvette[QUOTED] like this.
  12. Aug 4, 2025 at 7:05 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    DB Fab, I'd just make your own
  13. Aug 4, 2025 at 7:54 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Time to practice your aluminum welding
  14. Aug 4, 2025 at 8:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Plan to keep with mild steel
    I do have a spoolgun along with argon but I'd rather skip going that route
    Don't like working with aluminum :laughing:
  15. Aug 4, 2025 at 9:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    For sure
    I had remembered wrong and thought that they sold DXF plans themselves, not actual parts which I don't want
