  1. Aug 15, 2025 at 10:28 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I think the transmission might be on borrowed time at 150k miles. But iirc some of these newer Rams got better AISIN transmissions so maybe that got better.
  2. Aug 15, 2025 at 10:35 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nope
    Only 1 tons got the Aisin (as an option)
    But that auto isn't susceptible to anything major either
    Ozark_RegCab[QUOTED] likes this.
  3. Aug 15, 2025 at 10:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  4. Aug 15, 2025 at 11:01 AM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    High tomorrow is only 92°! Perfect Garage weather. First break in thus brutal heat in a while
    time623 likes this.
  5. Aug 15, 2025 at 11:14 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    It’s apparently at the warehouse in Airway Heights now. I just have to find time to go to the office and square up with the company and then go check on it.
    Kwikvette[QUOTED] and TACOTU3 like this.
  6. Aug 15, 2025 at 11:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So your welding table will be finished this weekend? :D
  7. Aug 15, 2025 at 11:26 AM
    TACOTU3
    Seems doable. The only part I might need a hand with is flipping it over to check/adjust flatness and flipping it back to weld. Might give it a try with Amber but I think the top weighs ~215 lbs…
  8. Aug 15, 2025 at 11:30 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ribs should all be parallel meaning your table will be pulled "flat" when you bolt up the ribs to the table top for welding
    This allows you to do everything with the table upside down (use some sawhorses if ya got some)
    TACOTU3[QUOTED] likes this.
  9. Aug 15, 2025 at 11:31 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Bouta try out this welding shit I guess
    TACOTU3 likes this.
  10. Aug 15, 2025 at 11:35 AM
    TACOTU3
    That’s the plan but if you don’t bolt it down too tight (they suggest ~30 ft/lb) adjustments can be made after it’s bolted together via dead blow hammer on any high sides; so I wanna flip it and get it as flat as possible. Suppose I can do that while it’s upside down too, but I’d rather make the extra effort to get it right.
  11. Aug 15, 2025 at 11:40 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's going to be in the 70s today mostly it seems. I welcome the break
  12. Aug 15, 2025 at 11:56 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    It’s kinda humid out here though, at least by inland northwest standards
  13. Aug 15, 2025 at 11:57 AM
    Speedytech7
    Yeah more than I prefer but not more than I can handle for the temperature at least
