  1. Nov 15, 2018 at 2:19 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  2. Nov 15, 2018 at 2:19 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Then you can do the joints too, they're annoying but you can do em. Can't do the double cardan joint though
  3. Nov 15, 2018 at 2:20 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Stupid me forgot to say;
    New Clutch, Flywheel, Clutch Fork, Bearings, Rear Main Seal, MT-90 done! waiting on a ride to go grab it.
    FLBAdrian and E30325 like this.
  4. Nov 15, 2018 at 2:21 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Yeah, we learned that from Monte lol. If you're double cardan is bad I suggest Napa. I had to replace my entire driveshaft.
  5. Nov 15, 2018 at 2:22 PM
    Sebz13
    Shane
    Maui Hawaii
    Hows the napa drive shaft holding up?
  6. Nov 15, 2018 at 2:24 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Good, I replaced it 6 months ago and haven't had a problem yet. New ujoints and carrier bearing as well. Was built to order for $700.
  7. Nov 15, 2018 at 2:43 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    If you have a gauge to check yourself, why not just go to a gas station & fill them yourself? Quicker than going to a tire shop even if they were to get it right the first time. But usually they don't so that's even more wasted time.
    40 psi all around? Why so much?
  8. Nov 15, 2018 at 2:48 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Lol, lazy ass!
  9. Nov 15, 2018 at 2:53 PM
    eon_blue
    Azusa, CA
    I ran 45 psi in my e rated KO2s awhile back and it was scary dangerous on the freeway - felt like I was going to lose control any time I hit a small bump. That was also back when I had stock suspension on and no weight in the bed. 35 psi usually felt about right
  10. Nov 15, 2018 at 2:58 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I've had 265/75r16 in Ds & Es & never needed to run them over 35 psi. I've got 285/75r16 in Es now & I normally run 32-33psi, sometimes 35psi but never over. 40 psi is unecsessary on our lightweight trucks.
  11. Nov 15, 2018 at 3:25 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Solid tranny mount for 3rz from DMZ fab
    FLBAdrian and MadTaco461 like this.
  12. Nov 15, 2018 at 3:30 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Cause we are not wimps?
  13. Nov 15, 2018 at 3:36 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Cause you guys like your rides rough. ;)
    E30325 and Crow_of_judgement like this.
  14. Nov 15, 2018 at 3:37 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Can't deny it lol
  15. Nov 15, 2018 at 3:38 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Wut
    Crow_of_judgement likes this.
  16. Nov 15, 2018 at 3:43 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
  17. Nov 15, 2018 at 3:56 PM
    JKO1998
    Utah
    Gonna go attempt a chem test, aughta be neat
  18. Nov 15, 2018 at 4:31 PM
    Speedytech7
    Really? That doesn't look like itd fit any part of the trans or xmember. Dez does do nice work tho.
  19. Nov 15, 2018 at 4:34 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Got my radio today. Is there anything special (setup) I need to do with it before using it or will it work as is with you guys?
    E30325 likes this.
  20. Nov 15, 2018 at 4:36 PM
    Speedytech7
    Yeah, get your HAM license
