  1. Nov 18, 2018 at 4:33 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    They are greasible too, so you are directly responsible for the amount of wear lmao
  2. Nov 18, 2018 at 4:35 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Doesn't need to run, the clutches are hydroscopic, they get water on them and they absorb it and they break down at an accelerated rate. Shifts may not even suffer until they get bad enough, they usually start slipping a little bit here and there, then more and more until you start losing gears
    Wulf likes this.
  3. Nov 18, 2018 at 4:37 PM
    Wulf
    rock raisin
    Wow you sound like the dealer trying to tell me "oil needs to be changed" because it's"not a lifetime" thing
    Running Board Man likes this.
  4. Nov 18, 2018 at 4:37 PM
    Wulf
    rock raisin
    That's the opposite of a restoration
  5. Nov 18, 2018 at 4:39 PM
    Speedytech7
    Nah, just serviced an auto or two, or seven. They're sorta one of those things that can be a make or break on an old vehicle cause they cost so much to repair. Could always swap a manual in though. Best to stay on top of them, and not ever let water in them, than to try and pretend all is well if you leave it alone. Cause then they strand you in a bad neighborhood
  6. Nov 18, 2018 at 4:40 PM
    Speedytech7
    Maybe you got lucky, helps that the 5VZ makes no power and doesn't stress the A340
  7. Nov 18, 2018 at 4:43 PM
    Speedytech7
    Mine doesn't either :/
  8. Nov 18, 2018 at 4:46 PM
    Speedytech7
    Burnouts happen because you've lost traction, once you've lost traction it's easy to keep spinning. Put some 33s on there and see if it still does it. Mine can light up a 33 with the manual just fine and I don't have the advantage of a torque converter multiplying my torque output
  9. Nov 18, 2018 at 5:41 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I can spin my 33's
    On wet pavement
  10. Nov 18, 2018 at 5:47 PM
    JKO1998
    Utah
    Stoner Question:
    Northern Alaska has periods of 24 hours in the day light and 24 hour in the dark, does the Southern Hemisphere do the same?
    I've never heard anyone talk about it
  11. Nov 18, 2018 at 5:48 PM
    JKO1998
    Utah
    I get mine going on accident when pulling off of a stop sign onto the highway haha
  12. Nov 18, 2018 at 5:48 PM
    Speedytech7
    Nah, just don't buy KO2s, though they do spin easily
  13. Nov 18, 2018 at 5:51 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Yes
    JKO1998[QUOTED] likes this.
  14. Nov 18, 2018 at 6:01 PM
    JKO1998
    Utah
    Makes sense, just never heard or read anything that says so
  15. Nov 18, 2018 at 6:01 PM
    Speedytech7
    Not a lot of folks down there
  16. Nov 18, 2018 at 6:04 PM
    Speedytech7
    300zx Skyscraper
  17. Nov 18, 2018 at 6:05 PM
    JKO1998
    Utah
    Southerners are bitchs
  18. Nov 18, 2018 at 6:08 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Hey!
  19. Nov 18, 2018 at 6:09 PM
    JKO1998
    Utah
    You read me
  20. Nov 18, 2018 at 6:09 PM
    Speedytech7
    North's in your states name
