  1. Dec 9, 2018 at 6:41 PM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
    Thanks! One less thing to worry about
    Sperrunner[QUOTED] likes this.
  2. Dec 9, 2018 at 6:41 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Gonna get the wheelers aal. It has the shims, and should lower my truck down a bit so it sits level. See my stinkbug a few posts back.
    The problem is, I cheaped out when I wanted a lift. I bought the low range 2" aal, the cheapest one out there at $39.00. No shims on it. Somehow I expected it not to squeak.
    Cant afford new leafs. I already replaced my perfectly fine oem leafs with cheapos from SD springs. Didn't know at the time that the leafs on these trucks are designed to sit flat. I regret doing that everyday.
  3. Dec 9, 2018 at 6:42 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Tried it, it tore when I took it offroad and got flexy.
  4. Dec 9, 2018 at 6:44 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Sounds like you just need a AAL that has the shims press into the leafs
    Blue92[QUOTED] likes this.
  5. Dec 9, 2018 at 6:46 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yup. Leafs didnt make a noise when I had a lift shackle. Now it sounds like an early 2000's silverado.
  6. Dec 9, 2018 at 6:47 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah that much be annoying. My AAL lucky came with the tabs on it.
    And atleast AAl kits are pretty cheap if you ever decide to swap them
  7. Dec 9, 2018 at 6:53 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yeah im thinking after Christmas Ill swap em. The wheelers one is $77 and it will take me like 4 hours tops to do it. This will be the 4th time Ive pulled the leafs so ive gotten pretty fast at it. Ive also memorized all the torque specs.
    I need to call Lowrange and tell them that their product sucks too, maybe they can revise it so others dont run into the same issue.
  8. Dec 9, 2018 at 7:15 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Sperrunner likes this.
  9. Dec 9, 2018 at 7:19 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Very 80s
    FLBAdrian[QUOTED] likes this.
  10. Dec 9, 2018 at 7:20 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Precisely. Except orange. I like orange.
  11. Dec 9, 2018 at 7:49 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  12. Dec 9, 2018 at 7:55 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Only flooded once
  13. Dec 9, 2018 at 8:03 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Instert photo of you neck deep in poo water
  14. Dec 9, 2018 at 8:16 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    All sorts of pics and vids from today on my build thread. Including this part.
    FLBAdrian and Sperrunner like this.
  15. Dec 9, 2018 at 8:19 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Hows the crawl box treating you?
  16. Dec 9, 2018 at 8:22 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    On a 99 those should be plugged if you don't have EGR
    970btu[QUOTED] and Wulf like this.
  17. Dec 9, 2018 at 8:23 PM
    Spoonman
    Jamie
    Alberta
    No changes so far. Still popping out of gear and no resolution yet.
    https://youtu.be/CU58BjR1G4A
    Pops out of gear at about 0:16 here. You can hear it and see me speed up. Only time I used it down a hill. And it does it of course.
    FLBAdrian likes this.
  18. Dec 9, 2018 at 8:35 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I like how your dog just follows behind you lol
    Prayn4surf and FLBAdrian like this.
  19. Dec 9, 2018 at 8:41 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    And you tink it might be because you received it damaged?
  20. Dec 9, 2018 at 8:46 PM
    Spoonman
    Jamie
    Alberta
    Doubt it...They sent me another new crawlbox and it does the exact same thing.
