  1. Dec 11, 2018 at 9:55 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I think spoon man has me ignored, mufckr doesn’t listen
  2. Dec 11, 2018 at 9:58 AM
    Wulf
    rock raisin
    BartMaster1234 likes this.
  3. Dec 11, 2018 at 9:59 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Tell him happy bday little dude! *gives him a pat on the head* yet he is taller than me lol
  4. Dec 11, 2018 at 9:59 AM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
  5. Dec 11, 2018 at 10:02 AM
    Wulf
    rock raisin
    sure you're talking about height? :luvya:
    FLBAdrian[QUOTED] and JKO1998 like this.
  6. Dec 11, 2018 at 10:22 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Today I learned not to make a sharp turn right after engaging 4hi. Had to turn down a snowy road off of one that was cleared. Got in the turn lane, engaged, and tried to make the turn. Truck did not like it. Felt like it bound up, had to straighten the wheel and try again, did fine once I got it straightened out.
    Also, got my center caps back. The color is nice, but I dont think Ill be going back to that body shop. Doesnt look like they sanded them much. 2 day job, so it looks like they rushed it. 1211181320.jpg
    Running Board Man and what road like this.
  7. Dec 11, 2018 at 10:23 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    You calling him wide?
  8. Dec 11, 2018 at 10:27 AM
    eon_blue
    Azusa, CA
    I blew a CV axle doing that once, careful. I was on a snowy road and pulled into a covered gas station...the concrete didn't have any snow/ice on it and felt it bind up to the point where it stopped the truck in it's tracks. Continued down the road for a couple miles in 4HI after filling up and started hearing this THUNKTHUNKTHUNK of a broken CV axle (inner joint blew apart)
    It might've already been compromised before the binding incident I dunno, but changing a CV axle off the side of the road in snow is no fun
  9. Dec 11, 2018 at 10:28 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    No noise after 10 miles. Ill look at it sometime tomorrow.
    eon_blue[QUOTED] likes this.
  10. Dec 11, 2018 at 10:32 AM
    eon_blue
    Azusa, CA
    It's probably fine, people bind up the front end all the time without knowing any better and probably on the trails too when the rocks get grippy. I think that axle was on it's last legs TBH
    we were headed to a pretty difficult trail to that day so if anything it was a blessing that it happened when it did, changing a CV on a snowy trail would've been worse
    Blue92[QUOTED] likes this.
  11. Dec 11, 2018 at 10:44 AM
    JKO1998
    Utah
    I don’t think it should do that.
    That is a terrible noise, I’ve gotten pretty good at transitioning from 4 to 2 WD, gotta use momentum.
    How much did you pay for the paint job?
  12. Dec 11, 2018 at 11:01 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Too much, even if it was free!!
    Blue92 and Running Board Man like this.
  13. Dec 11, 2018 at 11:02 AM
    JKO1998
    Utah
    That’s what I was thinking
  14. Dec 11, 2018 at 11:35 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    @Empty_Lord @BartMaster1234
    That S-runner was junk, well nothing on it that I wanted. Everything left was all fucked up. Was hoping to find the driver's weatherstrip & seatbelt.
    Center console was toast but I did snag the lower door for the console. Also got the blower motor, hope it's good. I think I paid too much for the blower motor though.
    Had factory sunroof.
    20181211_103713.jpg 20181211_103718.jpg 20181211_104030.jpg 20181211_104035.jpg
    There was a drift spec X-Runner parked in front of me. :rofl:
  15. Dec 11, 2018 at 11:37 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Oh & @BartMaster1234
    Seen a number of late 80s early 90s Cadillacs & Buicks. Not sure if the horns you need come out of those. Most I saw said A & F on them.
    FLBAdrian likes this.
  16. Dec 11, 2018 at 11:37 AM
    eon_blue
    Azusa, CA
    that one has a spider web near it, it's useless
  17. Dec 11, 2018 at 11:39 AM
    eon_blue
    Azusa, CA
    twin sticks like for rock crawling? Gives you a much lower range to use so you can crawl without feathering the throttle as much and burning up your clutch. At least that's my understanding and what I would want twin sticks for
  18. Dec 11, 2018 at 11:39 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I friggin hate spiders!
  19. Dec 11, 2018 at 11:39 AM
    eon_blue
    Azusa, CA
    I would rather be confronted with a pack of snakes than a big spider
    zero4[QUOTED] likes this.
  20. Dec 11, 2018 at 11:46 AM
    Wulf
    rock raisin
    Ah that's a crawl box, which is another gear reduction case that goes between the transmission and the stock t case. You are right though, it gives you another low gear 2.72, or 4:1 depending on setup to help with crawling
    Twin sticks for the factory t case give you 2 levers.
    One engages 4wd, the other toggles between high/low. If you're a chump like me with manual hubs you can use 2low while leaving the front hubs locked, which is useful if you have an auto locker up front
