  1. Dec 27, 2018 at 6:31 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I need some honest opinions. I’m Thinking I don’t like it.
  2. Dec 27, 2018 at 6:33 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not bad man, might need some storage options above the tire that can fold away or otherwise reveal the tire. But I think it's a solid start
  3. Dec 27, 2018 at 6:36 PM
    Spoonman
    Jamie
    Alberta
    There’s quite a bit of room in front of the fire, I have way more storage than before. But I’ll probably have to strap shit on top of the tire on trips though
  4. Dec 27, 2018 at 6:46 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Part of me likes it without the bedsides, but the other half of me thinks it looks great with the bedsides.
    Either way you’ve done a great job.
  5. Dec 27, 2018 at 7:14 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  6. Dec 27, 2018 at 7:21 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Cool, keep us posted
  7. Dec 27, 2018 at 7:24 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  8. Dec 27, 2018 at 7:26 PM
    cruiserguy
    Elijah
    SEKS
    Wtf? Whotf said a light bulb is gonna dissolve that bolt? Please tell me I'm being trolled
  9. Dec 27, 2018 at 7:26 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  10. Dec 27, 2018 at 7:27 PM
    cruiserguy
    Elijah
    SEKS
    Learn something new every day
  11. Dec 27, 2018 at 7:28 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Not without taking the valve cover off other than the nitric acid or alum method I mentioned. Actually another way is to break the ez out. Hardened metals are brittle so they can be shattered but that really depends on how the ez out is broken.
  12. Dec 27, 2018 at 7:29 PM
    cruiserguy
    Elijah
    SEKS
    You'll be fine with that
  13. Dec 27, 2018 at 7:30 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I'm only a smart ass or an asshole when appriopiate. ;)
  14. Dec 27, 2018 at 7:30 PM
    cruiserguy
    Elijah
    SEKS
    Unless it is the ground like some were saying
  15. Dec 27, 2018 at 7:33 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Can you take a picture of the ez out at an angle so I can see? Like anything other than straight on from the top.
  16. Dec 27, 2018 at 7:36 PM
    cruiserguy
    Elijah
    SEKS
    Dude you're right on the border with Meh-hee-co aren't ya? I was just thinking how your taco was dunked in poo water and I thought where the hell does something like that even happen? In Mission, TX. That's where
  17. Dec 27, 2018 at 7:36 PM
    cruiserguy
    Elijah
    SEKS
    Lol
  18. Dec 27, 2018 at 7:38 PM
    cruiserguy
    Elijah
    SEKS
    Just tap into that and use a mounting/securing bolt/screw
  19. Dec 27, 2018 at 7:39 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    A ez out is just hardened steel, usually high speed steel, same material that drill bits & good taps are made out of. Cheap taps & ez are just hardened carbon steel.
    You can drill it out with a solid carbide drill. But generally I wouldn't try it free hand. Carbide is harder than the ez out so it can drill it but carbide is even more brittle than hardened steel so it's even easier to break. And carbide ain't cheap.
    If you were close & brought it to me, I could get it out using the mill.
  20. Dec 27, 2018 at 7:41 PM
    cruiserguy
    Elijah
    SEKS
    Shoot, that's right. I'll keep trying to think
