  1. Jan 11, 2019 at 4:33 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That sounds like leaky injectors, they lose prime or flood the engine momentarily and you end up with that little gap before it works fine
    Area51Runner[QUOTED] likes this.
  2. Jan 11, 2019 at 4:34 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    hmmmm - easy fix?
  3. Jan 11, 2019 at 4:35 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    It wouldn't spin if the timing belt. You'd just hear the starter.
    Area51Runner likes this.
  4. Jan 11, 2019 at 4:37 PM
    Area51Runner
    totally intermittent - like maybe once or twice a month? i was thinking maybe the timing belt had lost some teeth to it or starting wearing funky. the injectors (now that I'm searching on that) sound like a very probable cause since what others are describing sounds like the behavior I'm seeing. always something, right?
  5. Jan 11, 2019 at 4:38 PM
    Speedytech7
    Eh, easy enough I suppose. Remove all the injectors and take them to be cleaned and flow tested. They'll check for leaks too. Then you just reinstall them and go on your merry way
  6. Jan 11, 2019 at 4:40 PM
    Area51Runner
    easy for you I should say, probably beyond my tinkering ability. still researching procedure - thanks for pointing me in that direction, definitely sounds familiar.
  7. Jan 11, 2019 at 4:42 PM
    Speedytech7
    No prob, of all the things to have to work on on the engine those aren't too terrible. Good opportunity to clean the throttle body and intake plenum.
  8. Jan 11, 2019 at 4:43 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Cold start? Hot start?
    X2 on it sounding like an injector issue
  9. Jan 11, 2019 at 4:47 PM
    Area51Runner
    happens on warm start - so if I shut it off, go in a store, come back and start (well, FAIL start lol)
  10. Jan 11, 2019 at 4:48 PM
    Speedytech7
    My buddy with a 4runner had that same issue when his fuel pump was dying, it's sort of a 50/50 on this one without putting a fuel pressure gauge on the injector rail to test
  11. Jan 11, 2019 at 4:49 PM
    Area51Runner
    interesting. I'll look at that as well. thx!
  12. Jan 11, 2019 at 4:54 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Wooooooord. I love fixing/working on stuff, but I reeeeaaallly like fixing/working on QUALITY stuff
  13. Jan 11, 2019 at 5:05 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    It’s been storming the past few days, going to be raining for the next seven days straight.
    I pulled my floormats out to dump the accumulated crud and noticed both of them had condensation and moisture on the bottoms.
    I felt the carpet and it’s pretty damp. Any idea where this water is coming from? Cowl maybe?
  14. Jan 11, 2019 at 5:09 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Is your window rolled down?
    Speedytech7[OP] likes this.
  15. Jan 11, 2019 at 5:09 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    What kind of question is that? Of course they're not rolled down.
  16. Jan 11, 2019 at 5:13 PM
    JKO1998
    Utah
    Just trying to narrow down the possibilities, no need to be aggressive
  17. Jan 11, 2019 at 5:14 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I wouldn't be asking if the windows were rolled down. I'm not an idiot.
    Crow_of_judgement likes this.
  18. Jan 11, 2019 at 5:15 PM
    cruiserguy
    Elijah
    SEKS
    Passenger side moisture could be due to plugged AC condensate drain
  19. Jan 11, 2019 at 5:15 PM
    JKO1998
    Utah
    Well you live in California soo :eek:.
    Maybe you should go start the dumpster fire thread for the night
  20. Jan 11, 2019 at 5:17 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Thanks, I'll have to give that a look once it stops raining. I do remember reading a thread where someone took some silicone and sealed the cowl area, still have a suspicion it could be a source.
