  1. Jan 21, 2019 at 5:45 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Learn how to spell Helen Keller
  2. Jan 21, 2019 at 5:46 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Are you removing it? The best piece of advice I got was “roll the differential forward” to remove it. An issue that arises is the driveshaft flange getting caught on the transmission bellhousing. Other people would have to remove a motor mount and jack up the engine, but rotating it forward worked like a charm.
  3. Jan 21, 2019 at 5:47 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  4. Jan 21, 2019 at 5:47 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Who lift that sand blast tank like it was nothing?
    Running Board Man likes this.
  5. Jan 21, 2019 at 5:48 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Nope. Tried that. Like I said, it’s on a mounting cushion on the rear that’s a stud so you have to lift it out of the crossmember, and then rotate it forward. Can’t use a jack to install it because of that either.
  6. Jan 21, 2019 at 5:48 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  7. Jan 21, 2019 at 5:48 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Remove and install a Tacoma front differential by yourself and then I’ll be impressed.
  8. Jan 21, 2019 at 5:48 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Ooooh
    I’ve gained a little since I last checked.
    As of this morning I’m 156#
  9. Jan 21, 2019 at 5:49 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Congrats! You have evolved from Toothpick to Bamboo Skewer.
    :luvya::luvya::luvya:
    what road likes this.
  10. Jan 21, 2019 at 5:50 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Im at 175 last i checked...
  11. Jan 21, 2019 at 5:50 PM
    JKO1998
    Utah
    Well damnit Bobby
  12. Jan 21, 2019 at 5:50 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Go re gear and ill do yours
  13. Jan 21, 2019 at 5:51 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    With what money, I just spend my last dollar on like 500 car horns.
  14. Jan 21, 2019 at 5:52 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Better get started on building kits so you can re gear so i can prove you wrong
  15. Jan 21, 2019 at 5:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It’s entirely possible with one person. But it would help a lot if you had two.
    I took the front differential out of a 1996 4Runner Limited at Pick-n-Pull for my 4x4 conversion and it took two people. Installing it is equally as difficult from the unusual shape and bulkines.
  16. Jan 21, 2019 at 5:53 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Install that front diff sitting in your basement on your frame. :luvya:
  17. Jan 21, 2019 at 5:55 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It’s not skilled work. All they’re doing is holding a heavy object and turning it forward to remove it.
    I had three people help me install or remove a front diff over the course of my swap, and only one of them had mechanical experience. This is more of a grunt work kind of job.
  18. Jan 21, 2019 at 6:00 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
  19. Jan 21, 2019 at 6:00 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It shouldn’t take that long. It’s either Allen or E-Torx can’t remember. I think it’s a larger Allen head. You’ll need to remove that, the vacuum lines, and the front differential mounting cushions. Can’t think if I’m missing anything.
  20. Jan 21, 2019 at 6:05 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    If it's a clamshell it'll be a 90 minute job and that's being considerate
