  1. Feb 1, 2019 at 8:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The clutch might actually need to be replaced as well. More steels and more clutch disks usually. Always helps to go for a fresh change of the recommended oil for the clutch first though just in case.
    Running Board Man likes this.
  2. Feb 1, 2019 at 8:41 PM
    Speedytech7
    Oof really?
  3. Feb 1, 2019 at 8:42 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    This why your welds look like this
  4. Feb 1, 2019 at 8:44 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    I changed the oil at the same time as the engine work was done and then again after the break in period. Any good websites for cross referencing part numbers? Might be able to get a higher friction clutch from another kawi that would fit in the Sherpa? Do you think just need stock steels and disks would do the trick?
  5. Feb 1, 2019 at 8:47 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    That’s what it said
    The wire he’s using looks like a rod though
    Once again, I don’t know shit about welding
  6. Feb 1, 2019 at 8:49 PM
    Speedytech7
    It's possible that more stock ones may work but thickness is usually the issue. I'd take tour disks out and use a caliper to measure them and compare to the FSM specs for them. Too many disks and steels will just bind it, but some bikes you can get away with it on. I used to go to Westside Motorsports for advice, they have some good techs. I'd give em a call for parts advice if your clutch doesn't spec out properly.
  7. Feb 1, 2019 at 8:50 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    This all you need to know about welding
  8. Feb 1, 2019 at 8:50 PM
    buckmaster243
    Buck
    Washington
    Alrighty thanks man
  9. Feb 1, 2019 at 8:50 PM
    Speedytech7
    The same advice applies for tig but it's usually a lot harder to get it that globby.
  10. Feb 1, 2019 at 8:51 PM
    JKO1998
    Utah
    I use to being able to run good beads with 6010 and 7018, my numbers are probably wrong butt fuck it
    Sperrunner[QUOTED] likes this.
  11. Feb 1, 2019 at 8:52 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I cant weld. Be cool to learn but i dont have the time. And dont feel like spending the money on a decent welder and trying to teach myself
  12. Feb 1, 2019 at 8:54 PM
    JKO1998
    Utah
    Most of my welding class was trial and error.
    Weld a plate, show the instructor, do it again, never had the dude in the booth with me.
    Most people just vaped in the classroom or in the booths
  13. Feb 1, 2019 at 8:56 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  14. Feb 1, 2019 at 9:02 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    “I rather buy gas” - @JKO1998
  15. Feb 1, 2019 at 9:04 PM
    JKO1998
    Utah
    It’s the best option
  16. Feb 1, 2019 at 9:04 PM
    eon_blue
    Azusa, CA
    Lightroom is awesome, I use that at work everyday.
    Speedytech7[OP] and Sperrunner like this.
  17. Feb 1, 2019 at 9:05 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    So you mean to say all them playboy models dont look that good in real life?
  18. Feb 1, 2019 at 9:06 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    You'll learn to appreciate your new camera, when it gives you higher resolution images to work with. The better the image you start with, the more you can do with them.
    JKO1998[QUOTED] likes this.
  19. Feb 1, 2019 at 9:06 PM
    eon_blue
    Azusa, CA
    That's what she said
    I can't believe no one else beat me to that, must be a slow night
  20. Feb 1, 2019 at 9:07 PM
    JKO1998
    Utah
    I think it’ll be fun to mess with, might have to put some money into eventually but for the extras.
    I’m hoping so, going home next weekend so hopefully I can get it under a tree.
