  1. Feb 8, 2019 at 8:27 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Drive safe homeslice
  2. Feb 8, 2019 at 8:27 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    oh... thats doable..
  3. Feb 8, 2019 at 8:28 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Yup! Typical German over engineering..... in a marker. Lol. These thing are awesome.
    cruiserguy[QUOTED] likes this.
  4. Feb 8, 2019 at 8:28 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Need a bump of coke
  5. Feb 8, 2019 at 8:28 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    You thought i meant resurfaced?
  6. Feb 8, 2019 at 8:28 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Adderall works better for that. Js
    Taco critter likes this.
  7. Feb 8, 2019 at 8:29 PM
    cruiserguy
    Elijah
    SEKS
    I'm all about over engineering! I gotta get my hands on a couple lol now I'm excited
    zero4[QUOTED] likes this.
  8. Feb 8, 2019 at 8:30 PM
    Empty_Lord
    Dan
    yes
  9. Feb 8, 2019 at 8:30 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah that would be dumb lol
  10. Feb 8, 2019 at 8:31 PM
    JKO1998
    Utah
    I think either would do fine
  11. Feb 8, 2019 at 8:32 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I could do it, it's cut vinyl not print though if that matters
  12. Feb 8, 2019 at 8:32 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    How big is the rotor (outside diameter) I might not be able to swing it in my lathe if too big to do the center bore. I might be able to do the bore on my mill if not much needs to be taken out. Bolt pattern shoukd be no problem as well as threading if I have the size tap. But what do you need threaded?
  13. Feb 8, 2019 at 8:33 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Rotors are threaded on 5 lugs
  14. Feb 8, 2019 at 8:35 PM
    JKO1998
    Utah
    I’m gonna get you money ASAP, I kinda forgot
  15. Feb 8, 2019 at 8:35 PM
    Empty_Lord
    Dan
    damn wouldnt look right. lol
    But some custom cut vinyl would be badass..
  16. Feb 8, 2019 at 8:36 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I won't even bother resurfacing rotors on my lathe. I try to avoid machining cast iron whenever possible, shit's messy. My rotors won't fit my lathe anyway but I rather pay $10ea to get them resurface by someone with a brake lathe.
  17. Feb 8, 2019 at 8:37 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    The holes for for the bolts. 5lug rotors bolt to the hub.
    I can get you sizes later and see if it’s something you can do
  18. Feb 8, 2019 at 8:37 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Ah I see, I assume like older American cars with studs & wheel bearings that go on the rotor?
    Running Board Man likes this.
  19. Feb 8, 2019 at 8:38 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Id just buy new rotors lol
  20. Feb 8, 2019 at 8:38 PM
    Empty_Lord
    Dan
    have him machine you custom 6 lug hubs and 6 lug rear axles so you can appear to be a 4wd
    Sperrunner[QUOTED] likes this.
