  1. Jan 11, 2019 at 3:27 PM
    Empty_Lord
    Empty_Lord Wallet abuser
    Dan
    Northwest Indiana/Chicagoland
    2001 Tacoma double cab 3.4l trd 4x4
    Almost 300k! Doug Thorley headers magnaflow cats & cat-back airaid intake tube color matched grille and mirrors front icon coilovers rear icon absorbers with deaver leafs total chaos upper control arms fj trail team wheels with 265/75r16 cooper discoverer st maxx Soon to be built engine with supercharger soon to be built a340f
    um... yea. i dont plan on fuckin up
    what road likes this.
  2. Jan 11, 2019 at 3:52 PM
    Speedytech7
    Zane
    PHX, AZ
    96 Patchwork Tacoma Wheeler & 1993 Land Cruiser
    Have a look at my builds --->
    I don't like doing angled engine mounts, the shit always ends up snagging. Little fore and aft control got em lined up though.
    cruiserguy likes this.
  3. Jan 11, 2019 at 4:00 PM
    Empty_Lord
    Dan
    just be grateful your not working on an intrepid.
    cruiserguy and Speedytech7 [OP] like this.
  4. Jan 11, 2019 at 4:01 PM
    JKO1998
    JKO1998 3rd Jens R Proof Stupidity Is Acquired Not Genetic
    Logan, Utah
    Cement 99 3.4 V6 4x4 Silver 02 3.4 V6 4x4
    Looks like something that one kid would do, why buy the real thing when you can make something that looks the same for cheaper.
    PVC steps
    Blue92 and Crow_of_judgement like this.
  5. Jan 11, 2019 at 4:02 PM
    Speedytech7
    Zane
    PHX, AZ
    I am believe me haha. I don't like working on shit that's just gonna fall apart even if I do a good job
  6. Jan 11, 2019 at 4:03 PM
    Crow_of_judgement
    Crow_of_judgement Judging you.
    William
    Houston texas
    04 tacoma double cab 4x4
    Snorkel, ome 881s Dakar leaf pack, magnaflow exhaust
    I mean, it works
  7. Jan 11, 2019 at 4:04 PM
    Speedytech7
    Zane
    PHX, AZ
    Does it, kinda looks like garbage that would fall apart if you used it
    Crow_of_judgement likes this.
  8. Jan 11, 2019 at 4:05 PM
    Crow_of_judgement
    William
    Houston texas
    Dunno, looks like at least 3 inch pvc, that stuffs pretty stout
  9. Jan 11, 2019 at 4:06 PM
    Empty_Lord
    Dan
    ive put engines in these turds.. its not fun... and the damn timing belts just break early anyway so your stuck doing it again.
    2 of the 3 ive done were dodge factory belts that snaped at 20-30k miles
  10. Jan 11, 2019 at 4:18 PM
    Speedytech7
    Zane
    PHX, AZ
    I'm not about that life, either there's too much valve soring pressure, there's a bad tensioner design or the belts are too thin. If you ask me it needed a chain
  11. Jan 11, 2019 at 4:21 PM
    Empty_Lord
    Dan
    its a flawed design. its like the mitsubishi belts. the edges wear away till it gets to thin and snaps.
    Speedytech7 [OP] likes this.
  12. Jan 11, 2019 at 4:28 PM
    Area51Runner
    Area51Runner Well-Known Member
    SAN FRANCISCO BAY
    '02 040 TRD DC 3.4 Runner
    OME 881, Dakar+AAL, Nitros, Cheap eBay Dorkel, 265/75/16s with 255/85/16s on the horizon
    is it possible for a timing belt (toyota belt) replaced in August 2015 and 21k miles ago needing to be replaced? Having that elusive intermittent starting issue where the damn engine cranks and starts but immediately dies or it will crank, start and die out with a rough idle. Trying to feather the pedal will just choke it out and it will die kinda like a misfire. If I wait a minute or so then try to crank it again, it will start up without an issue.
    Plug wires are going to be changed as well as plugs but after that, not sure what else other than maybe a good throttle body cleaning.
  13. Jan 11, 2019 at 4:33 PM
    Speedytech7
    Zane
    PHX, AZ
    That sounds like leaky injectors, they lose prime or flood the engine momentarily and you end up with that little gap before it works fine
    Area51Runner likes this.
  14. Jan 11, 2019 at 4:34 PM
    Area51Runner
    SAN FRANCISCO BAY
    hmmmm - easy fix?
  15. Jan 11, 2019 at 4:35 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    sf bay area
    04 tacoma prerunner
    It wouldn't spin if the timing belt. You'd just hear the starter.
  16. Jan 11, 2019 at 4:37 PM
    Area51Runner
    SAN FRANCISCO BAY
    totally intermittent - like maybe once or twice a month? i was thinking maybe the timing belt had lost some teeth to it or starting wearing funky. the injectors (now that I'm searching on that) sound like a very probable cause since what others are describing sounds like the behavior I'm seeing. always something, right?
  17. Jan 11, 2019 at 4:38 PM
    Speedytech7
    Zane
    PHX, AZ
    Eh, easy enough I suppose. Remove all the injectors and take them to be cleaned and flow tested. They'll check for leaks too. Then you just reinstall them and go on your merry way
  18. Jan 11, 2019 at 4:40 PM
    Area51Runner
    SAN FRANCISCO BAY
    easy for you I should say, probably beyond my tinkering ability. still researching procedure - thanks for pointing me in that direction, definitely sounds familiar.
  19. Jan 11, 2019 at 4:42 PM
    Speedytech7
    Zane
    PHX, AZ
    No prob, of all the things to have to work on on the engine those aren't too terrible. Good opportunity to clean the throttle body and intake plenum.
  20. Jan 11, 2019 at 4:43 PM
    Wulf
    Wulf TuRD
    Jake
    Denver
    amocaT 69
    Trail damage
    Cold start? Hot start?
    X2 on it sounding like an injector issue
