  1. Feb 22, 2019 at 8:09 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Shits gettin hotter bud
    zero4[QUOTED] likes this.
  2. Feb 22, 2019 at 8:54 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Damn I love Rota Broaches (annular cutters)!
  3. Feb 22, 2019 at 9:07 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    For a second I thought you left the key in the chuck and I was gonna holler at you. But that's the workpiece I guess. What're you broaching?
    cruiserguy and zero4[QUOTED] like this.
  4. Feb 22, 2019 at 9:12 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Lol, yeah that's the slug left over. I just use them to make big holes. Saves so much time rather than using multiple drill bits & stepping up to size then boring. And the left over slug can be used for something else.
    Just making an adapter to put a digital readout on my lathe's tailstock.
    The plate in the second pic is when I made those top plates for my shock buckets.
  5. Feb 22, 2019 at 9:51 AM
    JKO1998
    Utah
  6. Feb 22, 2019 at 9:52 AM
    eon_blue
    Azusa, CA
  7. Feb 22, 2019 at 10:01 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I have one that i belive works i can send you for cheap. Pay if it works.
  8. Feb 22, 2019 at 10:14 AM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    Alright boys, when I roll into 1st (0-5 mph) I've got a squealing/squeaking that sounds like its coming from my rear end. Almost sounds like a dirty brake would. Any suggestions? Driving me insane.
  9. Feb 22, 2019 at 10:16 AM
    eon_blue
    Azusa, CA
    Are you braking when it happens?
    FLBAdrian likes this.
  10. Feb 22, 2019 at 10:16 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Brake cleaner might have break dust in the back.
    eon_blue and Kpatt9[QUOTED] like this.
  11. Feb 22, 2019 at 10:19 AM
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
    No. Only does it at a slow roll.
  12. Feb 22, 2019 at 10:22 AM
    eon_blue
    Azusa, CA
    if it's squealing like a bad/dirty brake pad without braking then I wonder if maybe something (dirt, small rock, etc.) is trapped in the drum and making noise. Might have to pop it off and clean it
  13. Feb 22, 2019 at 10:22 AM
    eon_blue
    Azusa, CA
    If it's "chirping" like a bird then that's probably your u-joint(s) or maybe carrier bearing. I have the chirp happening at low speeds, at least that's when I can hear it, especially when going from forward to reverse.
    m3bassman and Kpatt9 like this.
  14. Feb 22, 2019 at 10:25 AM
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
    I did go wheeling last weekend and she got muddy as fck... I'll get under there this weekend and take a better look. Probably just a rock/dirt.
    eon_blue likes this.
  15. Feb 22, 2019 at 10:33 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
  16. Feb 22, 2019 at 10:36 AM
    Speedytech7
    I really like T-100, but be careful, that 3.0 is a turd of an engine that makes less power than the Taco 4cyl and blows headgaskets for fun if you don't put headers on it to correct the overheat problem for cyl 6. On the bright side it has had a head gasket job so it might be okay for a while.
    Running Board Man likes this.
  17. Feb 22, 2019 at 10:38 AM
    Fatal_Paradox
    Bardstown, KY
    I know nothing about the 3.0 so thanks for the warning. I will go back to looking for a 3.4 T100. Thanks !
  18. Feb 22, 2019 at 10:39 AM
    Speedytech7
    That is probably wise, although that T-100 did look really well cared for which is worth something still.
  19. Feb 22, 2019 at 10:41 AM
    Fatal_Paradox
    Bardstown, KY
    Yes I cant believe the shape and miles. If only it was a 3.4 !
  20. Feb 22, 2019 at 10:44 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Wow the news greatly exaggerated that. They showed footage of crazy snow out in the greater Phoenix metro area.
