  1. Mar 12, 2019 at 11:08 AM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    2002 Double Cab TRD OR
    Makes sense... I do like having the sway bar for daily use but it's currently resting on my skid plate and I'm wondering if it's causing the clunks I'm getting. I wanna rip the bitch out but I have a long drive next week through some windy country... I was getting concerned about how the truck would behave.
  2. Mar 12, 2019 at 11:08 AM
    TheMTBtacoGuy
    TheMTBtacoGuy Well-Known Member
    carsen
    Sandy, UT
    01 trd Supercharged 5spd, grandma Lexus
    • 3in old man emu lift • jba ucas • 34in bfg at on 16in method wheels • 2nd gen TRD supercharger (PO) • ARB front bumper • black metalic flake paint job (PO) • All pro off-road bead rack • smittybilt rtt • Borla exhaust (PO)
    When your in 4-wheel drive, and doing tight maneuvers do your tires chirp, even though the dif lock is off
  3. Mar 12, 2019 at 11:09 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    No embarrassment here, not even slightly. And you're only a "target" because you made yourself one. You can blame me for that if it gives you peace though. You have ever been a thorn in my side. Constantly trying to stir people up for no reason, life doesn't require the extra drama, and we don't live on a reality TV show. So I just decided I was done with it. I took your advice (I think the only real advice you've given on this forum) and ignored you from here out. Peace
    Crodell6[QUOTED] likes this.
  4. Mar 12, 2019 at 11:10 AM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    If you're on the pavement or a high traction surface, yes. Because when you're in 4wd, your front and rear wheels are locked together. Since we don't have a center diff, there's no allowance for the front wheels to spin at a different rate than the rears.
  5. Mar 12, 2019 at 11:11 AM
    eon_blue
    Azusa, CA
    Grease might've been the wrong word, it was from spraying them with dry lube 3 times a day for the last few months lol. Just collected a bunch of grime and crap.
    Also maybe a year ago before I knew better, I sprayed them with silicone spray a few times which might've been the real culprit.
  6. Mar 12, 2019 at 11:11 AM
    Speedytech7
    Resting on the skidplate is interesting, I've never seen one come that close before. Have you changed endlinks, how much tota front lift or drop do you have?
  7. Mar 12, 2019 at 11:12 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Did you get the bearing changed?
  8. Mar 12, 2019 at 11:13 AM
    Speedytech7
    Ah gotcha, that's one reason I'm not a fan of doing anything other than cleaning the uniballs. They end up attracting more dirt. The guys at SDHQ said to just wash them thouroughly with pressure after trips to avoid this.
  9. Mar 12, 2019 at 11:15 AM
    Speedytech7
    How are you liking the ARB bumper
  10. Mar 12, 2019 at 11:17 AM
    eon_blue
    Azusa, CA
    yeah I think that was my main issue back when I first installed the Kings, I didn't take care to wash them after every trip. This time around I'm going to be diligent about it and hopefully avoid needing to lubricate them to keep them quiet all the time
  11. Mar 12, 2019 at 11:18 AM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    Endlinks are stock. I just have OME882/nitrochargers in the front and dakars/nitrochargers in the rear. I do have a diff drop from toytec which caused me to space the front skid plate down to clear but spacing the front plate down shouldn't have brought the rear plate up... I really hate these all pro skids. Can't wait to replace them...
  12. Mar 12, 2019 at 11:19 AM
    Speedytech7
    Hell yeah send em flying! I dig it, used to use my relentless to bust those huge piles of plowed snow
  13. Mar 12, 2019 at 11:20 AM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    I have this stain remover that has done the work of Jesus on some of my pairs of jeans that were covered in oil. I forget the brand but I usually spray that shit on the stains, rub it in and let it sit for like 3 days to a week, then wash it and most of the time it comes out the first try.
  14. Mar 12, 2019 at 11:22 AM
    Speedytech7
    Hmm, that's very strange then. The only times I've heard if this happening has been when someone lowered a 6lug. But I'd eager it has something to do with the relief in the skids. Most skids have a pocket to accept part of the bar.
  15. Mar 12, 2019 at 11:27 AM
    JKO1998
    Utah
    Man, I can not find the drive to sweep the garage and pull my truck and start working on it, struggle bus is real.
    Crodell6 likes this.
  16. Mar 12, 2019 at 11:40 AM
    eon_blue
    Azusa, CA
    That's me almost every weekday...we get the driveway Mon - Fri and the girl that lives in the guesthouse gets it on weekends. So usually I have to work on my truck in the evening after work, I look forward to it during the day but once I get off work and the sun is going down, the struggle is real.
  17. Mar 12, 2019 at 11:42 AM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    One part of winter I will miss is being able to blame the lack of motivation to work on my truck on the cold...
    se7enine likes this.
  18. Mar 12, 2019 at 11:45 AM
    JKO1998
    Utah
    I’m gaining
  19. Mar 12, 2019 at 11:53 AM
    JKO1998
    Utah
    The stupid bitch is in the garage and the heater is on.
    Now I gotta go rent a tool or two.
    Any advice on UBJ’s?
    Lowers are easy
  20. Mar 12, 2019 at 12:04 PM
    Speedytech7
    Gonna need a ball joint press for sure. Might need a two jaw puller if the upper stud is stuck in the arm
    cruiserguy likes this.
