  1. Mar 15, 2019 at 9:59 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    WHAT IS WRONG WITH YOU!!!!! FIX IT YOU BASTARD!!!
  2. Mar 15, 2019 at 10:00 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    There ain’t fixing a engine block with holes in it
    Crodell6 likes this.
  3. Mar 15, 2019 at 10:01 AM
    Empty_Lord
    Dan
    We put a 3rz and a 5 speed in it from a rotted out taco after the engine blew. My friend still has the truck.
    cruiserguy likes this.
  4. Mar 15, 2019 at 10:01 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Anything can be done with the ingenuity mr.toyota mechanic
  5. Mar 15, 2019 at 10:03 AM
    Empty_Lord
    Dan
    Mr Toyota mechanic is busy setting up his new box
  6. Mar 15, 2019 at 10:03 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Ram air intake for his turbos
    Crodell6 and eon_blue[QUOTED] like this.
  7. Mar 15, 2019 at 10:04 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    I want that tool box
  8. Mar 15, 2019 at 10:19 AM
    Wulf
    rock raisin
    Someone in my local offroading circle threw a rod through the side of a Jeep 4.0L. they dropped the pan and pulled everything they could from that cylinder, jb welded a patch over the hole, and drove it home
  9. Mar 15, 2019 at 10:19 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Needs a lift kit and big tires
    Crodell6[QUOTED] likes this.
  10. Mar 15, 2019 at 10:20 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    And I get called a red neck for driving over my tailgate after backing into a tree?!? What does that make him?
  11. Mar 15, 2019 at 10:22 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Over land trailer tool box?
    what road likes this.
  12. Mar 15, 2019 at 10:23 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Ambitious
    what road[QUOTED] likes this.
  13. Mar 15, 2019 at 10:25 AM
    eon_blue
    Azusa, CA
    I'd say it makes him pretty damn resourceful....unless he's still driving around that Jeep with a JB welded engine fix, then he's a redneck too
    what road[QUOTED] and Sperrunner like this.
  14. Mar 15, 2019 at 10:26 AM
    eon_blue
    Azusa, CA
    Would be like using ratchet straps to hold your suspension together if you had a control arm failure on a remote trail...clever and resourceful, unless you decide to just keep it on that way instead of fixing it when you get home. Then you might be a redneck
    Sperrunner likes this.
  15. Mar 15, 2019 at 10:39 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Amd dllas was at home when he fucked his tail gate and was at home when he ran over it to fix it. Soooooo
    what road and eon_blue[QUOTED] like this.
  16. Mar 15, 2019 at 10:39 AM
    eon_blue
    Azusa, CA
    I thought it was just because he lives in Indiana
    what road and Sperrunner[QUOTED] like this.
  17. Mar 15, 2019 at 10:41 AM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    In my experience, these units are not the most accurate. Mostly depends on emissivity, but I wouldn't count on the readings for calibration purposes. The best use for these units is relative temps. For example, item A is 5 degrees warmer than item B. Again, the true temp of what you are seeing will not be very accurate.
    cruiserguy and Crodell6[QUOTED] like this.
  18. Mar 15, 2019 at 11:39 AM
    Empty_Lord
    Dan
    I should start a new trend! Lol
    Sperrunner[QUOTED] and Crodell6 like this.
  19. Mar 15, 2019 at 11:52 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Do it
  20. Mar 15, 2019 at 11:53 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    What’s wrong with your front diff?
    Just as long as you match the rear gear ratio you’ll be fine. There’s a three digit gear code on your VIN sticker, I believe 4.10 is B03A
