  1. Mar 19, 2019 at 1:55 PM
    eon_blue
    Azusa, CA
    ouch
    Crodell6[QUOTED] likes this.
  2. Mar 19, 2019 at 1:59 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I don't know. You certainly know better than any of us because its YOUR truck and you are right there working on it but I'm going to guess that it being submerged is playing a role. I wonder how that impacted rack bushings, rack, hell - everything. Unless you've replaced all of your suspension components...
    Everything I have done with this truck has been OEM for the most part. That's just me though. We've all seen the debates about 555 vs OEM vs Moog vs cheap imitation part. Not going there at all - only thought would be perhaps one of the parts you replaced with were not completely up to spec. Not trying to give you grief at all bud but an alignment shouldn't go bad 2 days later, unless it was a crap alignment to begin with. :notsure:
  3. Mar 19, 2019 at 2:14 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Can’t just leave one or the other thing unless you do custom wiring. It’s either all or nothing.
    Crodell6 likes this.
  4. Mar 19, 2019 at 2:15 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Friend of mine saw the KO2’s you gave me and was like “What the hell were you driving on, a cheese grater?”
    Crodell6 and eon_blue[QUOTED] like this.
  5. Mar 19, 2019 at 2:19 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    If you truly do want manual components, it’s all bolt on. All door components and door cards across the entire generation are compatible. Only issue I can think of is using 1995-2000 door cards versus 2001-2004 door cards due to the speaker size. I’m using 2004 Double Cab door components in my truck and I had to cut some shroud out of the door card to fit my round speakers.
    01x4[QUOTED] likes this.
  6. Mar 19, 2019 at 2:19 PM
    eon_blue
    Azusa, CA
    Rocks are unforgiving to tires :(
  7. Mar 19, 2019 at 2:45 PM
    Area51Runner
    well, like Ryan mentioned, perhaps the lower cost tech just was lazy and didn't do his job? IDK. My experience with alignment and trust me, I've learned the hard way - it not easy finding a reliable tech. hell, that goes with anytime you outsource work. I've taken the truck into Toyota and they claimed the alignment was the best it could get because of my suspension lift. They basically had me driving around with backwards shopping cart wheels. Took it into another shop - ended up paying nearly double what toyota charged me and they were nothing but pros the entire time. From customer service to actually doing the job right. Even with stock UCAs, everything was put into the green and no rubbing at all, even at full lock (that was with the 265/75 KO2s).
    So I guess it all depends on the shop in terms of quality. If they are going to do the work right, that alignment should be fine unless you hit a boulder head on :goingcrazy:
    In the end though, cost isn't a factor. Its all about the shop.
    cruiserguy and Running Board Man like this.
  8. Mar 19, 2019 at 2:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  9. Mar 19, 2019 at 3:09 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Can confirm
    Area51Runner likes this.
  10. Mar 19, 2019 at 3:18 PM
    JKO1998
    Utah
  11. Mar 19, 2019 at 3:19 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Damn tyler, why you pull your leafs off again
  12. Mar 19, 2019 at 3:20 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I stand by my statement. How else are you supposed to know the orientation if you didn't explicitly know that knowledge beforehand?
  13. Mar 19, 2019 at 3:20 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Ask google
    Or people on a car form
  14. Mar 19, 2019 at 3:21 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    The hell is a car form?
  15. Mar 19, 2019 at 3:23 PM
    JKO1998
    Utah
    When i swapped my Springs I took it upon myself to look at how the previous springs were installed before I went online
  16. Mar 19, 2019 at 3:33 PM
    JKO1998
    Utah
    Wut
  17. Mar 19, 2019 at 3:37 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Forum
  18. Mar 19, 2019 at 3:40 PM
    Area51Runner
  19. Mar 19, 2019 at 3:40 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Lay down painters tape, push on it to make the impression, then follow the edges with a super sharp exacto. Like brand new sharp
    Area51Runner[QUOTED] likes this.
  20. Mar 19, 2019 at 3:42 PM
    Area51Runner
    yep, @Sperrunner suggested the same. most plausible so far. Cboy suggested this -
    https://www.amazon.com/Gold-Label-Detailing-Applicator-Construction/dp/B07N95TXM8
    i'll give the painters tape/x-acto blade a try first. thx all.
