  1. Mar 30, 2019 at 7:56 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    My fronr bumper is powder coat, but that’s only because I hated the finish on my rear bumper which I painted myself.
  2. Mar 30, 2019 at 7:56 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Mine doesn’t and i have no issue
  3. Mar 30, 2019 at 7:57 PM
    eon_blue
    Azusa, CA
    Bedliner...use the kind that doesn't have a lot of texture if you don't want it looking too rough. Then apply it with a brush. Looks just like powder coat. And holds up better than rattle can paint.
  4. Mar 30, 2019 at 7:57 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    The Stock one?
    Thats yours. Though the bottom trim got nibbled on..
  5. Mar 30, 2019 at 7:58 PM
    eon_blue
    Azusa, CA
    I had window tint on my last car for 2+ years without issue until one day it became an issue...wasted a whole day at the Pasadena court house waiting to prove to a judge that I got it removed, sucked.
  6. Mar 30, 2019 at 7:58 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I need to do that to my rear bumper and hitch.
    My front Bumper isn’t going to see any rocks so the powder coat won’t get ruined LOL
    eon_blue[QUOTED] likes this.
  7. Mar 30, 2019 at 7:59 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    My truck didn’t have any stock. Then again my truck isn’t California spec
  8. Mar 30, 2019 at 8:01 PM
    eon_blue
    Azusa, CA
    I used bedliner on my fender flares and it works well, doesn't fade anymore and is a lot more resistant to scratches from tree branches.
  9. Mar 30, 2019 at 8:03 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    wasn't aware of that one. had to look it up... 100% correct - 27600 CVC. Damn, guess I should put them back on although just a fixit tix.
    http://leginfo.legislature.ca.gov/f...7600.&article=5.&highlight=true&keyword=flaps
    flap also apparently has to be as wide as the tire...
    Running Board Man and Sperrunner like this.
  10. Mar 30, 2019 at 8:04 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I just don’t feel like pulling the bumper off and sanding it all the way down to bare metal
  11. Mar 30, 2019 at 8:04 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  12. Mar 30, 2019 at 8:07 PM
    Area51Runner
    weird. although I guess you could argue, since it was sold (by the dealer) without flaps, then technically it shouldn't apply. Probably would have to produce proof it wasn't designed with them. again, all just a fix-it tix so no issue. then again, if you don't want to give some over zealous ofc a reason to stop you... lol
  13. Mar 30, 2019 at 8:10 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I mean I have no reason not to run them. The only reason I don’t is because it didn’t come with any
    Area51Runner[QUOTED] likes this.
  14. Mar 30, 2019 at 8:16 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’ve been ticketed before for not having them, but I found a temp solution
  15. Mar 30, 2019 at 8:19 PM
    Area51Runner
    what paint? That duplicolor wheel paint worked really well for me. I didn't sand but then again it wasn't too bad. The original clear was still present in some spots. I think I ended up doing like 4 or 5 light coats then 1 heavy followed by 2 clear.
  16. Mar 30, 2019 at 8:22 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Also painting them while they’re laying flat is easier than painting them while they are on the truck
  17. Mar 30, 2019 at 8:29 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Hmm i kinda like those lights on my bumper. Maybe I should do that
  18. Mar 30, 2019 at 8:35 PM
    eon_blue
    Azusa, CA
    It was the Duplicolor stuff... it just ran really bad, didn't stick at all. Also the texture from the black paint that was left underneath it showed through what did stick so even that looked really bad, I just need to clean them up real good and give them a proper sanding
  19. Mar 30, 2019 at 8:39 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Current state of the tundra. They gave me the wrong valve cover gasket for the passenger side. But pretty close to done.
    And I got the warning label for the driver side valve cover
    Because I’m that kinda guy
  20. Mar 30, 2019 at 8:40 PM
    Area51Runner
    I thought you wanted to sell your bumper
    Sperrunner[QUOTED] likes this.
