  1. Apr 15, 2019 at 8:58 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Yea
  2. Apr 15, 2019 at 8:59 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Idk
  3. Apr 15, 2019 at 9:20 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I could dig it, as long as I get to keep my big 4x4s. To offset the Latino-ness of me driving that thing. I'd take it to the park and b-ball courts on Sundays and show it off to my homies
    Sperrunner and JKO1998[QUOTED] like this.
  4. Apr 15, 2019 at 9:30 AM
    cruiserguy
    Elijah
    SEKS
    @Speedytech7
    So speedy, I reluctantly pulled my starter (I just did starter contacts and plunger like a year and a half ago). Nothing looks or looked off or amiss. But pushing the plunger and then messing with the Bendix you could feel as if two decades of brake dust could be jamming up those fine mechanical tolerances. So pulled the brushes and stator and armature or whatever those are all called and blew them out and put just a lil Teflon grease on the Bendix gear etc. Reassembled and the Bendix no longer has that little intermittent catch like before. Installed and starts great. Glad I didn't junk it. The Koyo bearings in it still are smooth as butter and brushes still had lots of life left.
    You were spot on with your diagnosis
  5. Apr 15, 2019 at 9:52 AM
    eon_blue
    Azusa, CA
    I don't throw shade, I cast mf'ing shadows
  6. Apr 15, 2019 at 10:54 AM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
  7. Apr 15, 2019 at 11:16 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Glad it was a simple fix! I helped @Digiratus do his starter on the V6 the other day and those bearings that support the Bendix had exploded and launched their BBs into the bellhousing. So I suppose that's a maintenance item, I dunno why but I always assumed it was supported by a bronze bushing not ball bearings
    Digiratus and cruiserguy[QUOTED] like this.
  8. Apr 15, 2019 at 11:22 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    You definitely sit higher with mine, and probably any that have power. The seat pan is just thicker through. I tend to recline my back a bit more to compensate. I have actually thought about removing the double thickness in the floor pan at the front, and redoing the rear brackets to get it lower, but probably won't, as I have gotten used to the difference now.
  9. Apr 15, 2019 at 11:27 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Lol wut
  10. Apr 15, 2019 at 11:38 AM
    cruiserguy
    Elijah
    SEKS
    I go every time I go see my brother in Waco :D best chicken tenders
  11. Apr 15, 2019 at 11:40 AM
    cruiserguy
    Elijah
    SEKS
    Nah, I'm a joker but I'd daily it in a heartbeat
  12. Apr 15, 2019 at 11:40 AM
    cruiserguy
    Elijah
    SEKS
    That's new to me..... Mmmm
  13. Apr 15, 2019 at 11:44 AM
    1997tacomav6
    Denver
    Crodell6 likes this.
  14. Apr 15, 2019 at 12:12 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    So the 22re is acting up. At idle it seems to be dropping down in rpms then going back up, then low again, high again etc. Like its lugging itself out. Drives fine though. My first thought is a failing alternator but what do I know :notsure:.
  15. Apr 15, 2019 at 12:24 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Vac leak maybe.
    Speedytech7[OP] and Crodell6 like this.
  16. Apr 15, 2019 at 12:25 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    that was my second thought.
  17. Apr 15, 2019 at 12:28 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Check the idle screw and see if its still got an o-ring. does it only happen when brakes are applied?
  18. Apr 15, 2019 at 12:32 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Idk havent really played with it much. Just noticed it coming back from a drive. So I guess it only does it when hot.
  19. Apr 15, 2019 at 12:33 PM
    Speedytech7
    Super easy to put a meter on and check voltage to put that theory to rest. But I bet it's vacuum or idle control related. The idle control on those is a PITA and there's tons of feet of vacuum line
  20. Apr 15, 2019 at 12:35 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    The idle has been an issue since day one lol. Im leaning more towards vacuum now. It was doing it after a drive so I guess it being hot is a factor.
