  1. May 8, 2019 at 11:05 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Forgot what it looked like with a bumper and the hood shut... Needs a wash real bad
  2. May 8, 2019 at 11:07 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I loved/miss the era of pop up headlights!
  3. May 8, 2019 at 11:08 PM
    Speedytech7
    This is the only car I've seen that comes stock with popup lights that don't hide entirely
  4. May 8, 2019 at 11:14 PM
    eon_blue
    Azusa, CA
    Lol when I was changing the bearings out on my coilovers one of the misalignment spacers popped out and flew across the shed where I keep my tools. I immediately figured it went someplace difficult and spent a half hour looking behind a bunch of shit that hasn't been moved in forever, only to find it laying in plain sight on the floor after I had about given up.
    zero4 and Running Board Man like this.
  5. May 8, 2019 at 11:15 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Come to think of it I think you're right. I never noticed that about them. Can you turn on the HLs without popping them up?
    I have seen it but it's done by body kits and some people do the mod where they don't close all the way but that's not the same. Ferrari F40 & Lambo Countach come to mind but they're not the same. They are actually seperate lights (signals & fogs).
  6. May 8, 2019 at 11:20 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Lol. I have played carpet commando, or should I say concrete commando many times in the garage looking for a nut, bolt, spring, clip, etc. Hasn't happened in a while luckily & I hope it don't happen much anymore. I'm too old & fat now!
    eon_blue[QUOTED] likes this.
  7. May 8, 2019 at 11:21 PM
    Speedytech7
    That's actually one of the ways they break haha, the switch will turn them on but the raise initiation won't trigger. But yeah if you pull the fuse for the flipup computer they'll just turn on and not popup... Kind kills the beam though. You can just lock them up but not on with a switch tho
    zero4[QUOTED] likes this.
  8. May 8, 2019 at 11:24 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I always wonder what people did to do that "mod".
  9. May 8, 2019 at 11:25 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Swap led headlights in and have them come half up.
  10. May 8, 2019 at 11:26 PM
    Speedytech7
    The perfect way to make LEDs work in halogen housings... Brilliant!
    Running Board Man likes this.
  11. May 8, 2019 at 11:27 PM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    Need help identifying this transmission. Guy says it’s a w56 but I’m thinking it’s an r150. What you guys think?
  12. May 8, 2019 at 11:28 PM
    Empty_Lord
    Dan
    Cafeful broski. Only true bros can know
    Also. Patent pending. Starting my own business, empty lighting. “We’ve got
    Nothin good for ya!”
  13. May 8, 2019 at 11:30 PM
    Speedytech7
    On miatas people unplug the computer and use the manual adjusters to raise the lights halfway. They won't move if the computer isn't plugged in. If I try to adjust the headlights with the manual adjusters on the Z the computer realizes a headlight is outta place and corrects it. They're only there for if your headlight motor is broken
  14. May 8, 2019 at 11:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    That doesn't look like an R150.
  15. May 8, 2019 at 11:33 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Looks like the guy is right, the casting and structure is consistent with a W56. Giveaway is the bellhousing, but it could be swapped.
    https://www.yotatech.com/forums/f116/transmission-id-without-firewall-plate-202800/
    There's something funky going on with that tail section.
  16. May 8, 2019 at 11:33 PM
    Speedytech7
    Looks like a w series but I can't tell for sure.
  17. May 8, 2019 at 11:38 PM
    BlackPearl
    Alex
    Toyota Tacoma TRD
  18. May 8, 2019 at 11:39 PM
    Speedytech7
    The w56 is only the trans, that double transfercase and tcase brake is from a Toyota pickup, drops on the wrong side for a Tacoma
  19. May 8, 2019 at 11:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    What is that, a parking brake pawl? I've never seen an output shaft like that.
  20. May 8, 2019 at 11:44 PM
    Speedytech7
    Driveshaft brake, usually done when people swap to calipers in the rear.
