  1. May 8, 2019 at 11:45 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    caliper and rotor for your parking brake... disc brake swap shit
  2. May 8, 2019 at 11:45 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yeah that makes sense.
  3. May 8, 2019 at 11:46 PM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    Should be picking this up in a week or so. Will have to figure out what to do with it. End goal is 5 speed sas. Will probably use the passenger drop since most axles are built this way.
  4. May 8, 2019 at 11:48 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well that trans won't do you any good, but the cases and DS brake are worth something if all the ranges work. Not sure if those cases mate to a taco trans but I bet someone makes an adapter if they dont
  5. May 8, 2019 at 11:53 PM
    BlackPearl
    Alex
    Toyota Tacoma TRD
    I’ll go with a R150, just need to find one and hope tcase will bolt on without the adapter.
    If not then adaptor I will get.
  6. May 8, 2019 at 11:54 PM
    BartMaster1234
    Tyler
    Flux Capacitor
  7. May 8, 2019 at 11:55 PM
    Speedytech7
  8. May 8, 2019 at 11:55 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You could fit all of downtown SF inside of that thing.
  9. May 8, 2019 at 11:58 PM
    Speedytech7
    I think the only feature that a more expensive blast cabinet could coerce me with would be some way to switch media's but switch or a lever
  10. May 9, 2019 at 12:02 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Switching media is definitely a pain. I need some new media, I'm pretty sure I've completely spent the glass bead I have in there trying to get that powdercoat off.
    I need to hardwire my cabinet for the aggregate vibrator, dust collector, and light. It's annoying having to plug three things in.
  11. May 9, 2019 at 2:48 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Lolol
  12. May 9, 2019 at 2:56 AM
    cruiserguy
    Elijah
    SEKS
    You remind me of Ricky from Trailer Park Boys lmfao hahaha
  13. May 9, 2019 at 4:20 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    What engine are you trying to put this behind?
    Running Board Man likes this.
  14. May 9, 2019 at 5:10 AM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    That FROR e-brake is common on crawlers with Toyota cases. Especially if axles/brakes have been swapped or like most Toyota axles, the bellcranks on the e-brake are rusted solid. Last I checked, most people aren’t parking their trucks and setting the e-brake with a wheel in the air...
  15. May 9, 2019 at 5:47 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    And forklifts, and construction equipment
  16. May 9, 2019 at 6:27 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Izuzu Impulse is the same only less hide and less popup
    Running Board Man and Crodell6 like this.
  17. May 9, 2019 at 6:43 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Turbo and all. They originally collaborated with Lotus. That's why they were extra crappy.
    Crodell6 and Hooks98tacoma like this.
  18. May 9, 2019 at 7:01 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Has anyone flipped their lower Rh/Lh A-arms?
    I was messing around with my truck last weekend and it looks like I could get 4+ deg caster and -1 camber pretty easily that way.
    Also looks like shock mount and ofc sway bar mount would need to be modified.
  19. May 9, 2019 at 7:04 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I doubt that's a thing. Just get spcs and you can adjust that stuff
  20. May 9, 2019 at 7:11 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I mean it definitely has not been a thing but it totally could be?
    I got Icon uppers, not as great as SPC's.
    If I get new arms, I'm just gonna make my own LT arms.
