  1. May 15, 2019 at 1:57 PM
    eon_blue
    Azusa, CA
    yeah i'm not sure which kind specifically but as long as it contains methanol
  2. May 15, 2019 at 1:57 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Bleh. You’re right.
    -25 is what most mfg’s use.
    I don’t know if it snows in Texas, but if it doesn’t regularly drop below freezing then you’re going to have a hard time finding it.
    I’m using premixed boost juice off Amazon.
  3. May 15, 2019 at 1:59 PM
    eon_blue
    Azusa, CA
    I'm this close to pulling the trigger on a NWTI weld together front plate bumper...just need to figure out if it works with most skid plates. I know some bumpers like All Pro only work with their skids, I don't want to buy another skid if I don't need to
    Don't know of anyone on here that has one...emailed their customer service hope to hear back soon
  4. May 15, 2019 at 2:00 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    If you can find the below freezing washer fluid, then use that.
  5. May 15, 2019 at 2:01 PM
    eon_blue
    Azusa, CA
    *pours Windex into methanol tank*
    Crow_of_judgement likes this.
  6. May 15, 2019 at 2:05 PM
    eon_blue
    Azusa, CA
    Calling @1997tacomav6
    1997tacomav6 likes this.
  7. May 15, 2019 at 2:15 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  8. May 15, 2019 at 2:17 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    My computer science professor gave us a quiz on our last class that's one question.
    He said "The answer is B"
  9. May 15, 2019 at 2:18 PM
    JKO1998
    Utah
    Error
  10. May 15, 2019 at 2:19 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    NullPointerException
  11. May 15, 2019 at 2:19 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Thats looks alot like moodle. If so, I feel sorry for you.
  12. May 15, 2019 at 2:20 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oh man, Moodle. My High School used it the first two years. When they switched to Canvas so many memes arose out of it.
    At all our student rallies people had signs that said “Bring Back Moodle” and “RIP Moodle”.
    Going back to your question it’s actually iLearn.
  13. May 15, 2019 at 2:22 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    It just seems poorly laid out for what it is, and there is a history of it not recording test scores at my school. My professors all claim that Blackboard is better.
  14. May 15, 2019 at 2:54 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    If you have to weld it together you should have the skills to make it work with whatever skids you have :luvya:
  15. May 15, 2019 at 2:55 PM
    eon_blue
    Azusa, CA
    Didn't say I was going to weld it together lol
    Although I might use this opportunity to learn, IDK yet
    Wulf[QUOTED] likes this.
  16. May 15, 2019 at 3:03 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  17. May 15, 2019 at 3:08 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Ah, hover mode didnt fully engage. Pretty common issue.
    Area51Runner[QUOTED] likes this.
  18. May 15, 2019 at 3:20 PM
    1997tacomav6
    Denver
    It all depends on your engines needs and if it’s supercharged and the amount of extra fuel( methonal) it needs for your application.
    I use my windshield tank, so A gallon will go=
    If you need or use a #1 nozzle probably 1500 miles,
    if you need a #2 nozzle 900 miles,
    a 3 nozzle 500 -600 miles.
    I run a #4 nozzle and need refilling about 400-500. Depending on how heavy your foot is.
    It only is in use for my needs when I hit 4 pounds of boost up. Otherwise it’s not spraying.
    Each engine is different for its needs.
    But I have a 2” pulley, ported supercharger, ported throttle body, 10 pounds of boost, so typically a #4 nozzle would not be used.
    If I keep my boost under 4 pounds I use zero methonal.
    So there are factors to consider
    If your not supercharged a #1 nozzle would probably work,
    I have around 40,000 miles on my methonal kit,
    I can’t say enough good stuff about my experiences with it.
    Wish I had know about it earlier but there was little to zero info
    here about methonal injection and I took a gamble.
    Now there are plenty of members adding the system with all the positive feedbacks.
    This is an excellent fix, but again some motors have issues.
    but unfortunately doesn't deal with tuning the ECU
    There are ping happy motors, no one is sure why,
    But it could be caused by
    Carbon issues in the valves intake and pistons,
    a bad or poor fuel pump pressure issues,
    A bad or poor fuel regulator,
    A dirty fuel filter in the tank,
    A dirty inline fuel filter,
    Dirty fuel injectors,
    eon_blue[QUOTED] likes this.
  19. May 15, 2019 at 3:22 PM
    Area51Runner
    Driver side - isn't there supposed to be some sort of plastic cover here?
  20. May 15, 2019 at 3:28 PM
    1997tacomav6
    Denver
    You can only use the -20 blue solution without additives. The additives will plug and or corrode the nozzle or the system, The blue -20 below is the ticket without additives.
    -40 is not to be used unless you find it with no additives.
    Typically the -40 below has lots of additives
    Or use boost juice that is 50/50
    -20 below is 30/70 and you can find it easily without additives
