  1. May 17, 2019 at 1:55 PM
    eon_blue
    Azusa, CA
    I'm just going off what I remember putting in last time, draining it doesn't get every last bit of it out
  2. May 17, 2019 at 1:57 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    true, but maybe it was how I parked because it took about 3.5 quarts
    as always YMMV
    eon_blue[QUOTED] likes this.
  3. May 17, 2019 at 1:59 PM
    eon_blue
    Azusa, CA
    yeah, @Kpatt9 just fill it until it starts to ooze out of the fill port. It won't take an entire 1 gallon/4 qt jug, so one of those will be enough.
  4. May 17, 2019 at 2:00 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    hmm should I troll the 3rd genners into thinking I went to the dark side?
  5. May 17, 2019 at 2:00 PM
    Wulf
    rock raisin
    I still need to change my fluid. I have some fresh MT90, curious to see what it looks like after 20k miles of stop and go and wheeling
  6. May 17, 2019 at 2:02 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    don't see it mentioned often but curious how many actually check to make sure their breather(s) are not clogged when changing diff fluid. Should be a periodic maintenance item on the checklist.
  7. May 17, 2019 at 2:04 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Their cheap enough and easy enough to get to that it should be a replace every 100k type thing. Especially since they can cause some serious headaches if they get clogged.
    Area51Runner[QUOTED] likes this.
  8. May 17, 2019 at 2:11 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  9. May 17, 2019 at 2:12 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    @Kpatt9, here you go. According to Haynes...
  10. May 17, 2019 at 2:15 PM
    Area51Runner
    agreed - just don't see them mentioned enough makes you wonder how many poor bastards aren't even thinking to or know to check :notsure:
  11. May 17, 2019 at 2:16 PM
    eon_blue
    Azusa, CA
    @Wulf 2.3 qts :luvya:
  12. May 17, 2019 at 2:16 PM
    Area51Runner
    Now this blows... If I ever hit 5/5 but missed the mega - oh the anger... a pathetic 20k instead of 44 mil because of one damn # lol
  13. May 17, 2019 at 2:20 PM
    Wulf
    rock raisin
    damn
    Haynes must be wrong :luvya:
    eon_blue[QUOTED] and Sperrunner like this.
  14. May 17, 2019 at 2:21 PM
    Wadar
    Wade
    A few.
    Can’t imagine there’s a real high likelihood of failure, it’s a rubber disc on top of a tube covered by a pressed cap to make a 1 way valve. I dissected one when I relocated the rear. And since diff oil smells why wouldn’t you want to taste it when you blow through it?
  15. May 17, 2019 at 2:24 PM
    Wulf
    rock raisin
    you learning how to weld now?
    turn the heat up and slow the wire speed down and slow down :luvya:
  16. May 17, 2019 at 2:25 PM
    Area51Runner
    When I did the relocate, I cleaned the stock breather up and plugged it into the line I was using for the extension - blew into it and barely any airflow. Removed the breather, sprayed cleaner into it and rinsed. Air blast to be sure it was clear. Plugged back in and checked - 1000 times better airflow out. Scary. Perhaps thats what caused my seal to fail - who knows. Oh well, breather mod in place with a new breather. All good.
    Wadar[QUOTED] likes this.
  17. May 17, 2019 at 2:26 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Area51Runner likes this.
  18. May 17, 2019 at 2:27 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I already have the Miller plugged in and the welding table setup, why not.
    Think my regulator is on the fritz, it doesn't expel gas every stroke.
  19. May 17, 2019 at 2:28 PM
    Area51Runner
    Make sure you put that meth jug OFF the table now
    :bananadead:
  20. May 17, 2019 at 2:30 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    1 year ago, I restored this. :luvya:
