  1. May 22, 2019 at 11:06 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Evening :D
    Area51Runner likes this.
  2. May 22, 2019 at 11:07 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    yeah, just call it a night. my money is on a wonky connection somewhere.
  3. May 22, 2019 at 11:08 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    It sure sounds like it's struggling. So it won't start at all? If you have spark & fuel and you think the starter is bad & the truck should start, try jump starting it... as in push start.
    Edit, oh wait, you're auto? For some reason I was thinking you were manual.
  4. May 22, 2019 at 11:14 PM
    Area51Runner
    everytime I see that damn user pic I start laughing to myself and think of chaka :rofl:
    https://youtu.be/jZZ_j2NENfg
    ALI3N_123[QUOTED] likes this.
  5. May 22, 2019 at 11:17 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    @BartMaster1234
    Just a thought, did you connect/check all the harness grounds? IIRC there's 3 main important chassis grounds, at the battery, on the firewall, & bottom of the block.
    BartMaster1234 likes this.
  6. May 22, 2019 at 11:19 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Got this txt yesterday. :rofl:
    My brother pointed out that 650 area code is bay area. Is one of yous messing with me?
  7. May 22, 2019 at 11:20 PM
    ALI3N_123
    Eric
    Austin, Texas
    Chaka :rofl:
  8. May 22, 2019 at 11:21 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Why do you think I pulled you out at Pismo? :rofl:
    I’ll have to pull a plug and check for spark, but I’m certain there’s fuel. I just changed the ‘O’ rings on the fuel rail.
    That stuff shouldn’t cause a slow cranking starter though.
    zero4[QUOTED] likes this.
  9. May 22, 2019 at 11:23 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I only touched two grounds, Firewall x Engine Block and Injector Harness x Manifold.
    I grounded the Firewall to the block, but I don’t think to the same bolt. Shouldn’t matter though since it’s the block.
  10. May 22, 2019 at 11:26 PM
    Area51Runner
  11. May 22, 2019 at 11:27 PM
    Area51Runner
    everything matters (and is suspect) when something is not working correctly.
    You should know that from your electrical engineering classes.
    cruiserguy likes this.
  12. May 22, 2019 at 11:28 PM
    Area51Runner
    650 is the San Francisco Peninsula
    Running Board Man likes this.
  13. May 22, 2019 at 11:30 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I’ll check the resistance if it makes you feel better but I’m pretty sure it’s grounding correctly. Didn’t touch the firewall attachment, only the block. I grounded it on the bare surface of the block wall.
    The injector harness should be okay, filed down the paint but again — a bad ground shouldn’t cause a convoluted starter.
  14. May 22, 2019 at 11:30 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Cause they/we always make the newbies do the hard work! But yeah, I remembered that everyone else was manual & you were auto so you got the honors. :)
  15. May 22, 2019 at 11:31 PM
    Area51Runner
    dont worry about me feeling better lol. i feel fine dude. all good.
  16. May 22, 2019 at 11:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    “I believe we have a tire issue.”
    I can’t get over that.
  17. May 22, 2019 at 11:39 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Lol, yeah I'll never forget that trip. I tried so hard not to laugh cause I didn't know the guy well but it was just to funny the way he said it. Sure did enlighten my mood at the time.
  18. May 22, 2019 at 11:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Have to go back there when Miguel’s Van is done.
  19. May 22, 2019 at 11:40 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Go meet him
  20. May 22, 2019 at 11:42 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Too far. I was gonna reply to tell him that I couldn't see him anymore & that there was someone else but I deleted it already. :rofl:
