  1. May 30, 2019 at 6:32 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Yup. Knowledge is power! Personally I’ll run only oem for the balljoints. on these trucks. My oems lasted 280k. That’s pretty impressive. My corolla is still on its originals at 760k
    cruiserguy[QUOTED] likes this.
  2. May 30, 2019 at 6:34 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Dang, most American cars would be on their fourth set of control arms by then lol.
  3. May 30, 2019 at 6:38 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    My dream Caddy is a 62 or 63 Coupe DeVille. I fell in love with them when I worked at the Cadillac junkyard. I could never afford one though, that's a hell of an expensive project car! But I still wish. That and a 66 El Camino.
    Although I love the color green, just not on almost all cars. But you get the idea.Mayo_02-850x567.jpg Mayo_03.jpg
    Minus the hood scoop.
  4. May 30, 2019 at 6:39 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    @Frontier Man 2500 and vans yours. Cut you a deal 3500$ you get a van,5lug and a frame
    Running Board Man likes this.
  5. May 30, 2019 at 6:39 PM
    Empty_Lord
    Dan
    only thing ive replaced is the struts and both front wheel bearings on the suspension
    one water pump
    2 alternators (one was just because the 1st replacement was noisy)
    valve cover gasket
    5 timing chain tensioner o rings (fuckers like to leak alot...)
    and 1 charcoal canister
    that damn cars amazing
    cruiserguy likes this.
  6. May 30, 2019 at 6:39 PM
    Empty_Lord
    Dan
    hell original condenser and radiator even after 2 front end accidents! The freon has never been touched and she still blows ice cold
    Sperrunner and cruiserguy like this.
  7. May 30, 2019 at 6:40 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah, especially on these tacos as well, just the design of it requires it to be a high quality ball joint. And if you use oem it should last very long. The design wasn't built for a lesser spec ball joint to be able to be successfully used there. But some do get good results with aftermarket but it's a bit of luck I'd imagine
  8. May 30, 2019 at 6:41 PM
    cruiserguy
    Elijah
    SEKS
    Oh that eggshell white is beauuuuuuutiful
  9. May 30, 2019 at 6:42 PM
    cruiserguy
    Elijah
    SEKS
    I'd pimp either of those aaaaaalll day long damn
  10. May 30, 2019 at 6:42 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yep, that 62 is peeeerfect! I'd take it just like that!
  11. May 30, 2019 at 6:44 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  12. May 30, 2019 at 6:45 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Pretty sure the timing chain o ring thing is leaking on my sisters rav4. The bottom of the timing cover always looks wet. Uses about a quart every 5k.
  13. May 30, 2019 at 6:45 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Looks like it needs a bbq grill mounted to it too!
  14. May 30, 2019 at 6:46 PM
    Empty_Lord
    Dan
    Eh. Might be. They suck to replace on a rav. Have to remove the intake manifold.
  15. May 30, 2019 at 6:46 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Approach angle is fucked cause of it. Needs a arb
  16. May 30, 2019 at 6:47 PM
    Empty_Lord
    Dan
    Corolla started leaking oil out of the head gasket. So next year for the 800k mark I might just finally rebuild the motor on a budget
    Running Board Man and Sperrunner like this.
  17. May 30, 2019 at 6:47 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    No grill guard and thats would be hot
    01x4[QUOTED] likes this.
  18. May 30, 2019 at 6:48 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    2jz swap
    Running Board Man and zero4 like this.
  19. May 30, 2019 at 6:48 PM
    cruiserguy
    Elijah
    SEKS
  20. May 30, 2019 at 6:49 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I think shes gonna be looking for a new ride in a year or so, so adding oil whenever needed is fine enough. Cars only got 120k on it, kinda sad that it uses that much oil considering how fun it is to drive. If I didnt need a truck, Id seriously consider a Rav.
