  1. May 31, 2019 at 9:39 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  2. May 31, 2019 at 9:40 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Pass. I won't give them a view on YouTube because somehow they make money by people watching their video
  3. May 31, 2019 at 9:41 AM
    cruiserguy
    Elijah
    SEKS
    Unless it's not Bros. Then lemme know and I'll peek at it
    Running Board Man likes this.
  4. May 31, 2019 at 9:50 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its some spoiled ass kid that that breaks his lambo trying to show off on a mud road above hollywood
  5. May 31, 2019 at 10:33 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    Does anyone know if I should be able to move my driveshaft around my carrier bearing ? Or should it be solid like a U-joint ?
  6. May 31, 2019 at 10:35 AM
    eon_blue
    Azusa, CA
    You mean the driveshaft has a bunch of play where the carrier bearing is? If it's excessive then the carrier bearing is probably in need of replacement, how does the rubber in the CB look?
    FLBAdrian likes this.
  7. May 31, 2019 at 10:35 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You mean like it woddles in the bearing?
  8. May 31, 2019 at 10:35 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Got them out of an old fleetwood. There was another 86 Deville that may have had them, but the hood was stuck closed.
  9. May 31, 2019 at 10:37 AM
    eon_blue
    Azusa, CA
    You should call your business...
    American....Auto............Horns...............................Unlimited
  10. May 31, 2019 at 10:38 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Will they be half the price of his
  11. May 31, 2019 at 10:38 AM
    Fatal_Paradox
    Bardstown, KY
    While under my truck I can grab my drive shaft on the left and right of the CB and push it up and down. Without much force.
  12. May 31, 2019 at 10:39 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Do you get vibration when driving
  13. May 31, 2019 at 10:40 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  14. May 31, 2019 at 10:40 AM
    Fatal_Paradox
    Bardstown, KY
    Im not 100% sure on the vibration. I do have a clicking like a bad U joint will make while going up steep hills or accelerating fast.
  15. May 31, 2019 at 10:40 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Horns Oughta Remind Negligent Youths
  16. May 31, 2019 at 10:41 AM
    eon_blue
    Azusa, CA
    I have to really push on mine to see any kind of movement where the CB is, if you can just grab the driveshaft and wiggle it around freely then it's probably no good
  17. May 31, 2019 at 10:41 AM
    Wulf
    rock raisin
  18. May 31, 2019 at 10:41 AM
    Fatal_Paradox
    Bardstown, KY
    @Speedytech7 Thanks man. That was my next question. Was should I get oem or SPICER. So I want to get some U-joints as well. Should I also get those spicer ?
  19. May 31, 2019 at 10:42 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I think spicer is who makes oem. And is way cheaper
  20. May 31, 2019 at 10:43 AM
    Speedytech7
    The OEM bearing is a Spicer part, the part you order from that website will have a Toyota part number on the rubber.
    Ujoints I would price out OEM but Spicer is quality so if that's easier I wouldnt hesitate to use em
