  1. May 31, 2019 at 1:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I fixed it you ass
  2. May 31, 2019 at 1:13 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    So does that mean we have a new anodizer(you)? :D
  3. May 31, 2019 at 1:13 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    post that again but without stars
  4. May 31, 2019 at 1:13 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    so you just need the center console part that has cup holders?
    not the bezel by the vents?
    i only try to pick best quality
    i'll probably get both if they are decent
  5. May 31, 2019 at 1:13 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Crow_of_judgement likes this.
  6. May 31, 2019 at 1:13 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Nice
  7. May 31, 2019 at 1:13 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I’ve come a long way with those harnesses. This is my current revision, v4. I sleeve all the wires on the main harness with plastic braiding, install Metri-Pack 530 fuse holders, Delphi 150 horn connectors, and 100% Stranded Copper GXL Automotive Wire rated for oil and gas immersion.
    cruiserguy[QUOTED] and zero4 like this.
  8. May 31, 2019 at 1:14 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Ok sounds good. Ill just build my own harness, but thanks for the offer. Would putting a ring terminal on the mounting bolt of the horns make a good ground, if I run the wire to my usual chassis ground spot?
    The stock horns only have one 12v wire going to them right? Pretty hard to mess up I take it?
  9. May 31, 2019 at 1:15 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    It’s tempting. Be cool to mess around with. And not terribly expensive to start up. I just don’t know how big of a market for anodizing small aluminum objects is
    zero4[QUOTED] likes this.
  10. May 31, 2019 at 1:15 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It’s pretty hard to mess it up. As long as you’re mounting to a good and grounded metal surface you should be fine.
    Make sure you test them before you mount them, the ‘C’ Horn likes to die often.
  11. May 31, 2019 at 1:15 PM
    Speedytech7
    Never heard of it before, huh
  12. May 31, 2019 at 1:17 PM
    JKO1998
    Utah
    Wait wut, the center console, between the seats
    GQ7227[QUOTED] likes this.
  13. May 31, 2019 at 1:17 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    My frame has the crc coating on it so utilizing a non-coated body panel bolt is fail safe, for me anyways.
    Thanks for helping me! Most companies wouldve told me to screw off and buy from them lol.
  14. May 31, 2019 at 1:17 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    If you can’t beat them, join them.
    Blue92[QUOTED] likes this.
  15. May 31, 2019 at 1:18 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Anodizing is no where near as dangerous as Parkerizing. I say go for it.
  16. May 31, 2019 at 1:18 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I never heard of it either. I just went there, saw notcrow's sn, then it led me to a F TW thread. Wow.
  17. May 31, 2019 at 1:19 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I mean it seems simple from the videos. I just dont wanna drop $$$ for a setup and do like 5 parts and be left with all this stuff and no use for it
  18. May 31, 2019 at 1:19 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I LOVE that your add-ons (wiring, connectors, etc) are good quality stuff. I won't be surprised at all when your business grows(it'll grow as much as you want it to) and becomes a sweet small biz. I'm excited for ya man
  19. May 31, 2019 at 1:19 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
  20. May 31, 2019 at 1:19 PM
    Wulf
    rock raisin
    Sperrunner likes this.
