  1. Jun 10, 2019 at 5:30 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    so rather a difficult task it is?
    Running Board Man likes this.
  2. Jun 10, 2019 at 5:30 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    @zero4 how hard is it to machine titanium?
    @zero4 is it true anodizing titanium makes it 100x cooler?
    zero4[QUOTED] and GQ7227 like this.
  3. Jun 10, 2019 at 5:31 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah, you also have to make sure the ecu is identical to your truck other then the fact it has to be a manual one vs a auto one
  4. Jun 10, 2019 at 5:31 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Only if you don't have much experience with replacing those kind of things. ;)
    GQ7227[QUOTED] and Sperrunner like this.
  5. Jun 10, 2019 at 5:32 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You wanna gsr swap the taco?
    zero4[QUOTED] likes this.
  6. Jun 10, 2019 at 5:32 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yes & Yes. :)
    Although I do anodize titanium I don't care for it myself that much & rarely anodize any of my own personal stuff.
    Sperrunner[QUOTED] likes this.
  7. Jun 10, 2019 at 5:33 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Sure!
  8. Jun 10, 2019 at 5:34 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    yes, no experience doing those kinds of things, scratch that idea
    Sperrunner likes this.
  9. Jun 10, 2019 at 5:34 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Tell me why my cousin is trying to say he has a typer R block with a stock gsr head and a LS tranny in his integra and that is a better setup then you know actually swapping a type r drive train in
  10. Jun 10, 2019 at 5:41 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Type R bottom end is stronger (stock internals & webbing). LS block doesn't have all the external webbing that GSR & Type R blocks have, no crank brace, & also no oil squirters for the pistons. GSR head will give higher compression on a Type R block cause it has smaller combustion chambers. But Type R head flows better & has better valvetrain (stock). LS tranny would be better for forced induction (longer gear ratios) but no LSD stock.
    I actually ran a US GSR block (B18C1), JDM Integra Si-Vtec pistons, GSR head with an adapter plate to run a Type R intake manifold, and a tranny from a B16B (JDM Civic Type R).... had a small diff so it was weaker but spooled up faster, gears were super short.
  11. Jun 10, 2019 at 5:45 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I forget but I think it was the other way around. You loose turning radius if you use T4R LBJs. (Please correct me if I'm wrong.)
  12. Jun 10, 2019 at 5:52 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    If you use 4Runner LBJ you have to use 4Runner rod ends too, which as far as I understand are smaller/weaker
  13. Jun 10, 2019 at 5:52 PM
    JKO1998
    Utah
    He doesn’t like here, leave him alone
  14. Jun 10, 2019 at 5:55 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Not exactly sure what's compatible from the 3 gen T4Rs, there maybe changes in the later yrs just like for Tacomas.
    The older 1st gen Tacomas used links & bushings for the sway bar but the later 1st gens used one piece ball joint style links. I forget when they changed over to that, somewhere around 99-00 I think. I'm not for sure but 3rd gen T4Rs never used the links with bushings.
  15. Jun 10, 2019 at 5:56 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yeah, @Frontier Man, ask m3bassman in the what did you do today thread or just PM him. He doesn't like coming to the thread anymore.
  16. Jun 10, 2019 at 5:58 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    It's easy to see what's identical. Just look up the.partsist for both vehicles. Whatever is identical will have the same p/n.
  17. Jun 10, 2019 at 5:58 PM
    JKO1998
    Utah
    The part of the 4R tierod that goes into the 4R LBJ is smaller than the Tacoma’s, so in order to use 4R LBJ’s on a Tacoma you have to use 4R tierods
  18. Jun 10, 2019 at 6:01 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I was talking about the sway bar end links in the post you quoted.
  19. Jun 10, 2019 at 6:01 PM
    JKO1998
    Utah
    The best thing to do with the sway bar is put it in the trash
  20. Jun 10, 2019 at 6:02 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I put mine back on a month ago.
    Running Board Man and cruiserguy like this.
