  1. Jun 15, 2019 at 2:21 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Your battery is crooked. :p
    Hooks98tacoma likes this.
  2. Jun 15, 2019 at 2:21 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I just wash off gunk under the car before i work on it with this. The 50 state blend comes in a bigger bottle that’s why i buy it lmao
  3. Jun 15, 2019 at 2:22 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I didn’t put the battery mounts down. I just installed the isolator
  4. Jun 15, 2019 at 2:29 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    For that purpose, way cheaper if you buy it by the gallon & use a SureShot style sprayer. Ok so I lied, this bottle is the chlorinated formula too.
  5. Jun 15, 2019 at 2:30 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Didn’t even know that was a option
    Crodell6 and zero4[QUOTED] like this.
  6. Jun 15, 2019 at 2:36 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I found this works pretty good for me atleast instead of clay baring
    Eagle One 850789 Surface Prep Mitt https://www.amazon.com/dp/B00ZPQ41GI/ref=cm_sw_r_cp_api_i_8rwbDbGCK58W7
    Eagle One 836608 Wipe and Shine Detailer - 23 oz. https://www.amazon.com/dp/B00J65I6OC/ref=cm_sw_r_cp_api_i_eswbDb5A8DHQR
  7. Jun 15, 2019 at 2:37 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Wut?? I mean those are marine batteries. As for the terminals idk. They came with the kit
    Crodell6[QUOTED] likes this.
  8. Jun 15, 2019 at 2:38 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Be kinda redundant seeing how this is a boat
  9. Jun 15, 2019 at 2:42 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Look at you showing off your lathe in the back:(:D
    zero4[QUOTED] and Sperrunner like this.
  10. Jun 15, 2019 at 2:43 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I can do that too :luvya:
  11. Jun 15, 2019 at 2:44 PM
    cruiserguy
    Elijah
    SEKS
  12. Jun 15, 2019 at 2:45 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Lmao, not what I was trying to do in that pic, that's just where I set the cans down when I bought em that day.
    cruiserguy[QUOTED] likes this.
  13. Jun 15, 2019 at 2:45 PM
    cruiserguy
    Elijah
    SEKS
    I really wish you'd start playing with those lathes and metal fab tools just SITTING IN A SHOP YOU HAVE FULL ANYTIME ACCESS TO. You don't need anything specific to make just start getting used to them man
    zero4 likes this.
  14. Jun 15, 2019 at 2:46 PM
    cruiserguy
    Elijah
    SEKS
    I know I know I'm just busting your chops smallz
    zero4[QUOTED] likes this.
  15. Jun 15, 2019 at 2:51 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Exactly, don't need to try and make something, just start machining stuff for practice to get a feel for the machines & how they work. Once you get familiar with them, then try to make something.
  16. Jun 15, 2019 at 2:51 PM
    cruiserguy
    Elijah
    SEKS
    What is your full time gig? Or what field, I guess?
  17. Jun 15, 2019 at 2:53 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I finally figured out all the controls on the mill. Haven’t tried the lathe
    cruiserguy and zero4[QUOTED] like this.
  18. Jun 15, 2019 at 2:54 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    He is a gardener
  19. Jun 15, 2019 at 2:54 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I worked in automotive, then electronic repair. Now, well I don't really want to say here but construction is part of the job. :D
  20. Jun 15, 2019 at 2:55 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Call is landscaping
