  1. Jun 16, 2019 at 12:44 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    It’ll tell you if your going to blow your engine up from running to lean. It’s good info to know
  2. Jun 16, 2019 at 12:45 PM
    TheMTBtacoGuy
    TheMTBtacoGuy Well-Known Member
    carsen
    Sandy, UT
    01 trd Supercharged 5spd, grandma Lexus
    • 3in old man emu lift • jba ucas • 34in bfg at on 16in method wheels • 2nd gen TRD supercharger (PO) • ARB front bumper • black metalic flake paint job (PO) • All pro off-road bead rack • smittybilt rtt • Borla exhaust (PO)
    True
  3. Jun 16, 2019 at 12:48 PM
    eon_blue
    Azusa, CA
    You can do that yourself, if I can do it anyone can lol. I just had a local welder drill the exhaust and weld the bung for me, the wiring part I did myself which was easy. And I suck at anything electrical.
    Running Board Man likes this.
  4. Jun 16, 2019 at 12:52 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    @TheMTBtacoGuy
    Go on Utor on Facebook and ask about it, they’ll send you to the right place.
  5. Jun 16, 2019 at 12:54 PM
    eon_blue
    Azusa, CA
    Your AFR numbers are good to know whether or not you have any fuel upgrades. In fact, the AFR gauge will let you know if you need to install fuel upgrades or not (probably do since most 3.4s need something).
    When in closed loop you want your AFR to at or around 14.7, once you start getting into boost you want to see that number get richer by going lower. If you mash the throttle and still see numbers in the high 13s or 14s then you're running way lean. Right now, without an AFR gauge you don't know if that's the case or not.
    At wide open throttle your system goes into open loop and the AFR should get richer, rich enough to prevent you from pinging and hurting the motor.
    Something like the 7th injector or methanol is programmed to start spraying extra fuel or meth into the intake when you hit certain boost/load and helps richen the AFR to prevent leaning out. This will all be reflected in the numbers you see on the AFR gauge.
    Someone here can probably explain it way better and in more technical detail than I can, but that's my basic understanding of it.
  6. Jun 16, 2019 at 12:55 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    At 9.5:1 compression I don't think the 5VZ is gonna care a whole lot, maybe 89 would help on hot days that you're climbing hills
  7. Jun 16, 2019 at 12:56 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    1500$ as is
  8. Jun 16, 2019 at 1:00 PM
    Empty_Lord
    Dan
    7th injector and a split second tuner.
    Or aem fic
  9. Jun 16, 2019 at 1:03 PM
    eon_blue
    Azusa, CA
    Can't tune our ECUs, although I think OVtune is working on something for 01-04s
  10. Jun 16, 2019 at 1:04 PM
    Speedytech7
    "Were" haven't had a word on it since then
  11. Jun 16, 2019 at 1:08 PM
    Empty_Lord
    Dan
    03-04. 01-02 is the older style ecu
  12. Jun 16, 2019 at 1:38 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Grinder, Bondo, and Paint, excuse you.
  13. Jun 16, 2019 at 1:38 PM
    JKO1998
    Utah
    He’s the expert here
  14. Jun 16, 2019 at 1:39 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    The car on the repair manual is red, therefore he is getting his car back red.
  15. Jun 16, 2019 at 1:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It looks fine ya pansies.
  16. Jun 16, 2019 at 1:58 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Is this the harbor freight light everyone is raving about?
    Running Board Man and FLBAdrian like this.
  17. Jun 16, 2019 at 2:02 PM
    JKO1998
    Utah
    That’s what the doctor uses when you swallow something magnetic
    FLBAdrian and Crodell6 like this.
  18. Jun 16, 2019 at 2:03 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I thought it was 03-04 only
    Crodell6 likes this.
  19. Jun 16, 2019 at 2:04 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Colonoscopy?
  20. Jun 16, 2019 at 2:04 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
